Can anyone recommend a good jack for the E70?
UrbanFlow
Post by UrbanFlow » Fri May 02, 2014 9:19 am
Hello all,
I'm turning into a bit of a detailer and want to remove my wheels to properly clean them and apply Gtechniq 5 wheel armour.
Having a 7 seater I have no jack on board.
Can anyone recommend a hydraulic jack or similar that is good quality without costing the earth?
Also, has anyone bought and used the adaptors like these…
http://www.ebay.co.uk/itm/BMW-X1-X3-X5- ... 3cdfa094b2
Any help appreciated, thanks.
Current Rides:
2007 Black X5 E70 3.0D SE - 7 Seater, Dynamic & Media Packs
1975 MGB Roadster with Rover SD1 V8 conversion, Offenhauser Manifold & Holley Carb - Straight lines only.
2005 Honda Hornet with Akrapovich zorst & other odds n sods.
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Re: Can anyone recommend a good jack for the E70?
Post by X5Sport » Fri May 02, 2014 10:43 am
I have those pads and they are fine.
I also have a 2-tonne (Kamasa) and 3-tonne trolley jack (Halfrauds).  The issue I have with the Halfrauds jack is that it has no wide head on the lifting arm so the pads sit on rather than in the arm head.  It's fine for a car but not so good with the pads.
I'm trying to find something that I can safely fit onto the head and that holds the adapter.  Probably needs a fabricator to make one up for me out of Aly.  If not then I might try to use a router to carve some slots into one if the pads.
The Kamasa jack is 25 years old and has a better head.  If you can find a jack with a wide head on the lifting arm that would be best.
I got the 3-tonne one on a discount so it was less than £50.  TBH a 2-tonne jack will do if you are only working on one corner at a time.
I always use an axle stand as a back up device and chock the opposite side wheels.
UrbanFlow
Post by UrbanFlow » Fri May 02, 2014 12:44 pm
Thanks very much for the advice.
Current Rides:
Previous Ride:
dennys
Post by dennys » Fri May 02, 2014 8:38 pm
http://www.machinemart.co.uk/shop/produ ... ley%20jack
I use one of these and made my own jack plug out of hard plastic easily lifts up an X5 E70
CURRENT CAR 40D M SPORT CARBON BLACK 20 INCH ALLOYS
UrbanFlow
Post by UrbanFlow » Sun May 04, 2014 12:11 pm
Great thanks.
Current Rides:
Previous Ride:
Raj
Post by Raj » Mon May 05, 2014 9:16 pm
I have an Arcan 3T trolley jack. It has the large pad plate so ideal for those jacking pads.
Something like THIS would be ideal and you can just use the central jacking point under the front for example to lift the whole front up (or the rear diff to lift the rear).
