Won't turn over
GermanWhip
Won't turn over
Post by GermanWhip » Fri Apr 11, 2014 12:24 pm
Hi all, in the morning when I turn the key the ignition comes on but the car won't turn over, doesn't even try. It's happened 3 times now. I've had a new starter motor fitted. Also, it can be started by clipping a wire on the back of the starter.. then after driving it seems to work normally?
The autobox seems fine and goes into park no problem. Any ideas? Must be something electrical..
Smeeagain
Re: Won't turn over
Post by Smeeagain » Fri Apr 11, 2014 12:58 pm
Solenoid perhaps ?
Re: Won't turn over
Post by X5Sport » Fri Apr 11, 2014 1:17 pm
Sticky solenoid would be one choice - even on a new/refurbed unit.  Though your adding a separate wire does point to something else.
Try moving the gearshift to Neutral and then see if the same fault occurs.  It might be the position sensor on the gearbox is incorrectly thinking the car is in a drive gear rather than P or N which would also inhibit the starter.
I can't remember if the immobiliser inhibits the starter if it fails to correctly read the key.  If the battery is flat then the system may not be detecting properly.
Does it lock/unlock with no issues via the remote key?
Smeeagain
Re: Won't turn over
Post by Smeeagain » Fri Apr 11, 2014 1:41 pm
[quote="GermanWhip"]
Definitely think it is important to remember that these starters whilst new once, are usually refurbished ones ......
GermanWhip
Re: Won't turn over
Post by GermanWhip » Fri Apr 11, 2014 2:34 pm
It done it before and after fitting a new starter.. so it isn't the starter.. unless the old one and new one have exactly the same fault..
Re: Won't turn over
Post by X5Sport » Fri Apr 11, 2014 3:03 pm
In that case you are looking at whatever feeds the solenoid.  As above it could be gearbox selector position sensor inhibiting, immobiliser inhibiting, ignition switch itself.
The gearbox selector one is something that has happened on the forum before.
GermanWhip
Re: Won't turn over
Post by GermanWhip » Thu Apr 24, 2014 5:16 pm
Update on this, it stopped (after the garage looked over it but couldn't see anything) for over a week, but it's started happening again.
Usually in the morning, but today.. it started fine in the morning.. I drove 2 miles to the shop, came out and it WOULD NOT crank again. I tried the other key as I had this on me, nothing. The only way is to bypass the starter motor and it cranks and fires.
Any ideas? it's not the starter motor or battery. And it's only sometimes.
I've also noticed when driving the selector can be moved into neutral, is that normal? I thought it should lock in drive ..?
Re: Won't turn over
Post by X5Sport » Thu Apr 24, 2014 7:10 pm
Normal.
Re: Won't turn over
Post by Horizon » Thu Apr 24, 2014 7:12 pm
Do a search for ignition switch, has been known to throw some weird symptoms too. I was talking to a guy who had a 5 series who had the similar problem, turned out to be a dicky connection on the wiring loom  multiplug going to the ignition switch. Took it to BMW and they couldn't find the problem, but the garage down the road went straight too it.
GermanWhip
Re: Won't turn over
Post by GermanWhip » Fri Apr 25, 2014 12:41 pm
[quote="Horizon"]
Thanks, this is what I'm edging towards, it's SO frustrating as it is COMPLETELY random when it will happen.. so frigging annoying.
Smeeagain
Re: Won't turn over
Post by Smeeagain » Tue Apr 29, 2014 4:49 pm
Which suggests it is a loose wore/loose connection and depending precisely how you bypass everything (from a security point of view don't post back explaining it) then you may well be bypassing the dodgy element
Smee
Bargain Bucket
Re: Won't turn over
Post by Bargain Bucket » Tue Apr 29, 2014 5:27 pm
A loose what? I read "loose whore" at first  :)).
briankerrys47
Re: Won't turn over
Post by briankerrys47 » Tue Apr 29, 2014 6:28 pm
[quote="Bargain Bucket"]
[/quote]Simlar  O:-)
Smeeagain
Re: Won't turn over
Post by Smeeagain » Wed Apr 30, 2014 11:58 am
or even a loose wire. Wouldn't a whore by loose dy definition anyway ....  ;)
Re: Won't turn over
Post by X5Sport » Wed Apr 30, 2014 3:16 pm
[quote="Smeeagain"]
Certainly sloppy.......in need of tightening  :P
