M sport suspension removal and replace with SE
kjb1
Post by kjb1 » Sun Mar 23, 2014 9:27 am
Hi all.  Question.  Can the suspension be swapped out on the m sport in replace for SE suspension? has anyone here ever done it? or vice versa etc.  And also, if it is possible, is anyone willing to swap? lol.  Let me know, as in my m sport suspension for SE.
martin33100
Re: M sport suspension removal and replace with SE
Post by martin33100 » Sun Mar 23, 2014 11:36 am
[quote="kjb1"]
[/quote]We have the sports suspension on our E70 and I was also looking into the differences.
When I looked on the BMW parts computer to compare sports vs standard suspension I found the part no.s were different for the front shocks and springs and the rear shocks and airbags, the air bag pump and suspension arms looked the same.
The only thing I didn't check was to see if the anti-roll bars were different.
Raj
Post by Raj » Sun Mar 23, 2014 11:42 am
It's all interchangeable for sure. Just a matter of the cost etc.
Can't see why the rear airbags would be different but the shocks for sure and front springs as the rates will be different.
kjb1
Post by kjb1 » Sun Mar 23, 2014 11:42 am
Wonder if anyone has done this?
sid10
Post by sid10 » Sun Mar 23, 2014 12:01 pm
Seems a bit extreme , why not try an X5 with 19" wheels m sport first at a dealers , then one without Runflats , I noticed that the tyres are the main problem once they have been used 4mm & below they are very bumpy on the roads . Quite a few have changed to none Runflats on here see if they are local to compare !
kjb1
Post by kjb1 » Sun Mar 23, 2014 12:11 pm
[quote="Raj"]
Same here, would not have thought the bags would be different aswell!!
Post by X5Sport » Sun Mar 23, 2014 1:09 pm
Higher operating pressure?  Thicker construction (increased stiffness) perhaps?
martin33100
Post by martin33100 » Sun Mar 23, 2014 1:49 pm
[quote="kjb1"]
[quote="Raj"]
[/quote]The bag acts as a  spring on the rear so if you put an uprated spring on the front I guess you need to uprate the bags at the rear. There must be some difference as there is two parts no.s for with and without sports suspension.
kjb1
Post by kjb1 » Sun Mar 23, 2014 2:06 pm
well either way I'm interested in doing it.  Ride a tad to firm for me for a 4x4, they ard about lazy cruising
martin33100
Post by martin33100 » Sun Mar 23, 2014 2:12 pm
[quote="kjb1"]
[/quote]Are you still on run flats?.
My brother inlaws Q7 S line on 21's had a softer ride than our X5 but the X5 did get good reviews on how it takes the corners.
kjb1
Post by kjb1 » Sun Mar 23, 2014 2:14 pm
yes still on rft's but I'm guessing it wont make a massive difference going non rft!
JimmySpeed
Post by JimmySpeed » Sun Mar 23, 2014 2:19 pm
[quote="kjb1"]
It will, it's a massive difference. I would try it first unless your current tyres are new
Sent from my SM-N9005 using Tapatalk
kjb1
Post by kjb1 » Sun Mar 23, 2014 2:23 pm
current bridgestones are brand new ln front and good life rear
JimmySpeed
Post by JimmySpeed » Sun Mar 23, 2014 3:18 pm
Oh, it seems a bit wasteful to change them then. Although you could probably get good money for them on ebay...
Sent from my SM-P600 using Tapatalk
martin33100
Post by martin33100 » Sun Mar 23, 2014 3:46 pm
Only reason we are still on run flats is we had over 6mm on the tyres when we bought our car.
