best place for dpf removal/delete + remap
Re: best place for dpf removal/delete + remap
You just need to hope they don't 'tap' the box to see if there's a hollow noise to it........
martin33100
[/quote]I doubt they will do that as they would have to remove the insulated heat shield to give it a tap
For reference the BMW dpf's are made very well and they are much thicker than the likes of what VAG use.
If you remove just the dpf block you could leave the cat in place.
You can tell if the DPF has been removed, or gutted on a car easy enough. Look at your exhaust tail pipe, if its got a working DPF the inside of the tailpipe will be clean and almost shiny
If the DPF has been removed just run your finger inside and you will have a black sooty finger
Hence cars with no DPF had down turned exhaust tips.
- 535dboy
Cant' say I'd risk it anymore either
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
Nor me given that VOSA could seize the vehicle for non-compliance. As long as you don't get caught then fine, but if you do....... I would not want to lose a £60k car thanks very much. The potential penalties could include no insurance, non-compliant vehicle, underpaying VED so resulting in HMRC recovery & fines, points, loss of the car etc etc.
Would the missing DPF not cause an engine light if the system could not regenerate? Or can that be programmed out? I don't know what sensor tells the ECU that the system needs to regen, but I know if mine is mid-cycle when I turn the engine off then a number of engine fan or fans keep running. Some part of the DDE system must tell the fan to run on?
There is a pressure sensor in the DPF that has a preset differential, when the back pressure increases due to the clogging of the filter it triggers a regen, only if the temperature of the Exhaust is sufficient to burn off the soot, so if the light comes on due to back pressure the regen will occur if the temperature is high enough, hence the need to take it for a blast to generate enough heat to burn off the soot.
martin33100
[/quote]Someone like Jason at BWchiptune can program out the DPF function.
Nat
HI,
I will start by saying what I know about DPF fits on the back of a stamp.
Howevere I have heard/read lots about these filters getting blocked and they being a lot of money to replace.
Did you know these DPF can be cleaned. Yes indeed...............
All you need is a large sonic cleaner................the same kind of machine they use to clean motorbike carbs, etc etc.
Regards,
Nat.
Regards,
Nat.
martin33100
[quote="Nat"]
HI,
Regards,
Nat.
[/quote]You can also clean them on the car with a product like Wurth DPF cleaner http://www.wurth.co.uk/technical-chemic ... aner-400ml.
I have been told it works well, you spray it into the dpf via the pressure sensor pipe and then once its soaked in you do a forced regen.
HI,
Regards,
Nat.
Nine468
Im learning a lot about these dpf,s....
But how do you do a forced regen.?
Ta.
Ta.
Dave W.
BMW G05 X5 40D
BMW G05 X5 40D
martin33100
[quote="Nine468"]
Ta.
[/quote]Most independent BMW specialists will have the diagnostic kit to do a forced regen but even then if the back pressure sensor is reading to high I think that will even stop a forced regen.
I know there was a guy on the BMWland forum that had DPF issues and the car wouldn't regen on its own due to the back pressure sensor readings being too high, he put a very small split in the hose that goes to the pressure sensor to fall the ecu ie it gave it a lower reading and then it did a regen straight away. You obviously take the risk of doing something like that yourself as BMW has put the safe guards in there for a reason.
Ta.
- 535dboy
Makes petrols seem more reasonable when you factor this in with higher costs of diesel the possible fuel savings are now outweighed.
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
Except that Euro VI requires all new petrol cars to be fitted with GPF systems - the equivalent of a DPF.
Seems few are to escape.
Never anthropomorphise computers. They hate that.- 535dboy
Bugger
The amount I've eaten this Xmas they'll be expecting me to put some filter on my arse next time I take my push bike out!!!
Bugger
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
At least diesel owners will have a spare tank to wee in...... :puke:
