Good Evening
I took my 2003 X5 to the indi menders and they have quoted £550 to supply and fit my buggered aircon compressor and clutch.
That's a lot of money for a few days of the year when we need to use aircon........I think you'll all agree.
Can any of you suggest what I should do?
Is £550 a pisstake?
Anyone know where I can source these parts at a reasonable price, after all its a 10 year old car!
Raward
E53 Expensive AirCon fault
2003 X5 pre-facelift
Re: E53 Expensive AirCon fault
The problem is that unless the system is run regularly (at least once a month) the seals dry out due to the fluid also being a lubricant and that's that. To be honest I never turn mine off. The systems can lose up to 15% gas volume per year normally so need checking every 5 years or so, more often if not used. It's called 'Climate Control' for a reason. It's not just a/c and needs using.
Citroen were well known for it a few years back, and that price is about what I would expect from an Indy, BMW will probably want over £1k.
- shadrack
that will be right as air con compressor will be expensive and they can be a pita to fit
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
See what someone like Quarry Motors will charge for a 2nd hand compressor and then either fit yourself or have your indy fit it.
http://www.ebay.co.uk/itm/BMW-X5-SE-D-A ... 53f491c4a8
05 Mercedes SL350
05 Mercedes SL350
