Problem with lighting on dash.
dirtymonkey29
Post by dirtymonkey29 » Fri Jun 08, 2012 2:15 pm
We need at least 12 for a xdrivers calendar
sp3ctre
Administrator
Administrator
Re: Problem with lighting on dash.
Post by sp3ctre » Fri Jun 08, 2012 2:47 pm
Condor.....have you tried deleting any xdrivers bookmarks and then using a search engine to find us again?  It's what I had to do, and then recreated the bookmarks and it's been fine since.  Works on Safari, Firefox12, IE9 and IOS.  I think you said you use Opera so I'm not sure how that might work with this...... :sorry:
and we need MORE females to balance the team, not less..... :ok:
I'm not sure you need to use a search engine to find the site, but more so make sure you don't use a pre-existing bookmark.
If I understand right this should cure it:
delete cookies (xdrivers one or all, doesn't matter)
clear browse history
delete any xdrivers bookmark you may have
close your browser
type the xdrivers url into the address bar
login (either accept 120 mins or choose "forever"
That "should" cure the issue...
Post by X5Sport » Fri Jun 08, 2012 3:14 pm
No particular reason to use a search engine....was taking the lazy approach, need to type less :P
Rusty
Post by Rusty » Fri Jun 08, 2012 8:45 pm
I couldn't initially log in via cr@patalk, but after logging in via a pc after typing in the URL (I don't have a bookmark as I always use mobile devices) all was well and accessible via all.
That worked for me :)
Runabout - E92 3 Series Coupe
