On parking up the car tonight, noticed the blower fan was running - left it for 20mins - still running. Started the car and tried to turn the blower off by reducing the speed to zero (no indicator bars showing) - however blower will not totally stop - one bar showing and AUTO still illuminated. I've pulled the fuse to save the battery in the mean time
Does anyone know what the fault is please?
Climate Control Blower
- Rusty
Sounds like your hedgehog, your FSR, or the Final Stage Resistor ( one and the same)
Have a search on here and you will find plenty of info including where to find it etc
Hope that helps
Hope that helps
Runabout - E92 3 Series Coupe
Re: Climate Control Blower
[quote=""rusty nail""]Sounds like your hedgehog, your FSR, or the Final Stage Resistor ( one and the same)
Hope that helps
Sent from my iPad using Tapatalk[/quote]
Thanks very much - I note some Members hold that the hedgehog fault is found only on the pre-facelifts wheras mines a facelift. Worth a go I suppose - might be an age-related issue (the facelifts are getting old too!)
Hope that helps
Best get one from the dealers as well, when I bought my car the dealer fitted a new one. Lasted 10 months, up on me buying a proper one I find that it was a copy. The OME come with I think 2 yrs warranty, takes 10 mins to fit.
Thanks for all the replies
Sorted it (I think)
Turned off aux heat and aux vent via scanner - left for a few hours - re-enabled - everything OK
Know that my battery is not so clever (6 years old and just survived the winter) so suspect it's a low volts issue affecting the PCs
Sorted it (I think)
If it does turn out to be the dreaded hedgehog that will kill your battery - beware!
