on board comp is it faulty
hi, i recentley bought a x5 diesel and never tried the onboard comp.the indicator stalk moves each function in turn but i cant reset any of the data ie mpg /distance /etc any advise please thanks kev
Press and hold when you get to the item you want to reset or do it on the nav screen if you have nav.
Didn't you get an owners pack with manuals in it?
- X5Driver
If you have the nav you have to reset by selecting the item on the nav screen then push the right button then select recalculate. Maybe another way though
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
Re: on board comp is it faulty
i have tried to hold the centre of the stalk for 5sec but nothing happens.also i think its had a updated sat nav installed .the user manual is being forwarded by prev owner kev
If it originally had a Sat nav and that's been replaced, then I have a sneaking suspicion you will have lost the necessary connections to set/reset those functions as well as the clock. Or at least, that's the experience of some others here..
