screeching sound from engine
Hello.
For the last month or so i can hear a screeching sound when driving along. This happens all the time when driving, a sort of a supercharger sound. The sounds seem to come from the front pulley area although i'm not exactly sure.
Upon searching the web the common theme seems to be idler pulleys, is there a way of checking this without taking off the belts. It's a 2004 4.4 with the n62 engine i believe and if it's not the pulleys then what else could it be.
Thanks.
Thanks.
Black 4.4 sport 2004
- X5Driver
Re: screeching sound from engine
Had the same on my 4.8 and it was the belt tensioner, if it wasnt that alternator bearings were most likely.
Think you can get new bearings fitted at certain places as alternators can be scary money.
Mine had belts removed and hand spinning the tensioner you could hear and feel it.
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
So is it a belt off job to manuelly check the pulleys ?
- X5Driver
Yes it is really, I think if you could get under it on a ramp one of those stethoscope things against the alternator would eliminate that but you wouldnt want to get this near the pulley and not the sort of thing you can do on the ground with belts whipping around.
Think it was called a deflection pulley and cost about £25+VAT + Labour and wasnt a long job so I thought was worth a try as thats only about 20 miles of petrol in this thing anyway (note that is a joke before all the help full comments about fuel economy being below norm)
- X5Driver
Thinking about it I thing its one of those 1/2" square drive tensioners where you just take the pressure of the spring with a ratchet/breaker bar and slip the belt off.... or that could be just the Discovery
[quote=""X5Driver""]......... only about 20 miles of petrol in this thing anyway (note that is a joke before all the help full comments about fuel economy being below norm)[/quote]
As if we would.........
- X5Driver
Bl**dy Derv Boys, here they come...
Still not here though....
Thanks for the input, i'll check them this weekend.
- pvr
[quote=""X5Sport""][quote=""X5Driver""]......... only about 20 miles of petrol in this thing anyway (note that is a joke before all the help full comments about fuel economy being below norm)[/quote]
I had this image in mind from someone up front feeding the engine ...
911 50th anniversary -
- X5Driver
Funny how you build a picture in your mind of someone and I didnt expect you to look like that
Do you run it on house coal or anthracite?
Any special kind of tool required to remove the belts or is it just sockets..
- X5Driver
To remove belts it's just the 1/2 inch drive ratchet into the tensioner then a few 8 or 10 mm bolts for tensioner. All from memory so may be slightly off
