keeps coming on but erratically, like every few days to weeks.
is this a sign that one (or all) needs replacing? Is there a way to tell which one is suspect or just to change the lot at next tyre change?
thanks
Paul
Tyre pressure warning lamp
bonerp
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
Re: Tyre pressure warning lamp
Have you got TPM Sensors in the wheels? I know some versions (4.8is?) have or had. Could be the battey needs replacing in them?
Our E53 3.0d only uses the ABS sensors, but that occasionally throws a light if there's a weather change. Not as often as you are seeing. It's never actually come on when there's been a real flat though
bonerp
abs sensors for tyre pressure? How do they work then?
Mine has the tyre pressure sensors yes. Can just batteries be purchased then?
thanks
thanks
weirdfish
[quote=""bonerp""]abs sensors for tyre pressure? How do they work then?
thanks[/quote]
ABS sensors work by detecting the rolling radius of the wheel/tyre, as a tyre deflates the rolling radius changes, as for the batteries in the valve type sensors, I think it's a bit more involved, for a start you have to know which one is playing up, and for that you need diagnostic equipment.
thanks[/quote]
- CondorX5
I *think* I saw a thread on xoutpost about this - as I recall, the battery-type sensors were on the 4.6is. My 4.8is, a 2005, has the ABS sensors, not sure if it was a date related change or if just the 4.6is had the battery-powered ones. The ABS ones also give the occasional random light - easy enough to reset once checked and possibly weather related, that's true.
Weirdfish, just to clarify - both types are "tyre pressure sensors" - one works on the rolling diameter of the wheel - ie the ABS type - if there is a change in rolling diameter, ie the wheel loses pressure, the sensor light comes on. The battery ones as said are somewhat more involved, generally viewed as a PITA if they go wrong, and are expensive little jobbies to replace, for what they are.
X5 2005 Le Mans Blue 4.8is
- x555
thanks[/quote]
Im pretty sure that yours will have abs wheel speed sensors (also known as pulse generators)and not the battery wheel type as only the older x's had them mate.
thanks[/quote]
