fuel pump relay
wizard-58
fuel pump relay
Post by wizard-58 » Mon Nov 10, 2025 12:02 pm
good morning well after a week of trials and troubles I'm no nearer ..yes high pressure fuel pump is a good shout ..why it should just go I've no idea .
so far I've tried 3 new glow plug control units a new SCV valve and I've just replaced the crankshaft sensor ( that's a lovely job ) taking a reading at R/w and B wires there's a constant 5v at yellow wire also a constant 5v which should be a switching voltage if engine is turned by hand with ignition on I didn't get this so changed it and no luck I've just done a fuel check running through from boot to the front and every stage there is a strong flow of fuel .I've checked the electrical connections to injectors they all give 0,2ohms . did a leak off test and hardly got a any fuel a couple of inch's up the pipe with about 12 cranks of the engine. we tried directly spraying a form of easy start and it doesn't even cough . I've also done at least a dozen diagnostic checks .code reads deletes and rechecks the only 2 codes that keep appearing is 4203 glow control unit and 4687 throttle Valve actuator ? I get NO fuel codes .. rail pressure sensor appears to be reading correctly .although when cranking expected pressure should be 398 bar .but actual pressure goes up to 398 for a millisecond then drops right off ( FRP control valve? ) voltage reading is correct /but no code for it ?
Im spending today researching all that I can think of online .
any and all suggestions will be checked .cheers
Paul
fuel pump relay
Post by Leslie » Mon Nov 10, 2025 10:19 pm
Mt x5sd had throttle valve controller error , its a common issue , oil leaks in and damages the electronics , see plenty of new ones on ebay and not expensive and not your issue either , it seems mainly to close on ignition off and allow the engine to stop with less vibration so I've heard due to lack of air to compress , it has some role in regens I heard ,no idea what though but mine regens fine without it as its been broke a long time.
wizard-58
fuel pump relay
Post by wizard-58 » Tue Nov 11, 2025 3:33 pm
ok Ive sort of ruled out both the codes as being the problem if either were faulty it would cause issues but shouldnt stop it starting or trying to start at least ..so Im going to bite the bullet again this weekend and take the manifold off .I got a set of new glow plugs ( dont believe theyre faulty ) but while im in there this time ..im then going to do a full compression test and do fuel pressure test at the main rail feed and depending on the results ill have I hope an idea of which way to proceed .
fuel pump relay
Post by Leslie » Tue Nov 11, 2025 6:07 pm
If its still alarming for heater plugs/controller maybe the controller isnt getting any power due to a fuse .wiring issue ? I think its unlikely new ones are faulty .
wizard-58
fuel pump relay
Post by wizard-58 » Mon Nov 17, 2025 2:32 pm
Okey dokey bit of an update cheers Leslie we have basically ruled out the control unit as being an electrical anomaly possibly because car isnt actually running .will do full exploration if it continues when we get her running ..compression test was very encouraging . cylinders as follows ;
1; 23 bar 2; 25 bar 3; 26 bar 4; 25bar or for us oldies 340 psi 360 psi 380 psi and 360 psi respectively all with in 15% of each other and very good ive been led to believe has car has done over 180'000m bmw say 16 bar at 325'000k is good so happy there ..Im now 99% sure it is the HPFP so have a reconditioned unit on its way hope to be able to fit this at the weekend delivery dependent .will up date as soon as completed .
wizard-58
fuel pump relay
Post by wizard-58 » Mon Nov 24, 2025 11:56 am
next up date not encouraging .new/recon HPFP fitted at weekend and same results ??? even spraying easy start directly into throttle body only achieves a very minor cough no attempt to really start or run .now totally out of ideas ???
fuel pump relay
Post by Leslie » Mon Nov 24, 2025 2:14 pm
Hi reading back you say throttle valve actuator , i dismissed this earlier as I have it too but if it won't run with easy start them the easy start can't be getting through , can you take of the boost pipe infront of the throttle valve and see if the butterfly is actually open with ignition on, it closes with ignition of or rather should but they often fail open and spray some easy start in there , hold it open if needed as if may have failed closed , as it really should be if it gets a source fuel, thats all I can think of . :thumbup:
wizard-58
fuel pump relay
Post by wizard-58 » Mon Nov 24, 2025 3:09 pm
yeah already done that mate by spraying easy start in to throttle valve I get a slight cough I didnt look inside though ill have a go this weekend when im at it again Ive also got new fuel pump pressure control valve coming ..not getting a code but hey ho in for a penny as they say .
fuel pump relay
Post by Leslie » Mon Nov 24, 2025 8:58 pm
be worth checking the egr valve isn't stuck open too :D
wizard-58
fuel pump relay
Post by wizard-58 » Sun Nov 30, 2025 1:56 pm
ok have cured the throttle body code ( new throttle body ) old one was stuck closed now when spraying easy start car fires and runs 2 seconds ..but have now got code for crankshaft sensor even though already changed it .have done electrical test and getting constant 5v reading on switching wire which was reason for change originally .plan to strip out and recheck new crankshaft sensor and also do a fuel pressure test at rail from hpfp next Saturday .feel I'm getting close to the problem :D
fuel pump relay
Post by Leslie » Sun Nov 30, 2025 5:19 pm
I hope u are getting somewhere , it can run anyay now , the throttle valve staying closed is unusual and the intermittent nature of it makes fault finding tricky till it failed totally, I might change mine soon :thumbsup: so if it was getting fuel it would go , the crank sensor does tell the ecu its spinning over and if the rail pressure ix high enough it should go. Maybe refit the old one now if you have it , was the new crank sensor genuine ? If so its unlikely to be faulty , unlikely but not impossible I guess.
wizard-58
fuel pump relay
Post by wizard-58 » Thu Dec 11, 2025 1:52 pm
Hi all Ok update Car is now running havnt taken it for a long run yet as still putting bits n pieces back on ..inner wheel arche and under panels etc ..being an old boy I have to do things in stages .. to make it quick CRANKSHAFT sensor was not seated correctly so air gap was wrong .not sending correct info to the pump so no pressure .Please if you fit a new one make sure its seated and run a simple check .to see if its switching correctly before reinstalling starter motor and all the gubins ..I also fitted new fuel pressure regulator on end of rail along with new HPFP new throttle body and new EGR ..+ while off the ground a new propshaft quibo and full engine service .if anybody has any questions ill be happy to try and help .oh and new glow plugs and relay .. hopefully now the car will last me out :rofl: :rofl:
fuel pump relay
Post by X5Sport » Thu Dec 11, 2025 5:42 pm
What a palava, and all for an apparently simple issue. Shame the car could not have actually flagged that as an error and saved you time, money, frustration etc. That’s the trouble with modern cars though. You often get an error code that is meaningless, or points in the wrong direction.
I’ve not played with INPA or ISTA, but both may have workflows to go through and eliminate items. You probably need to be a computer scientist to use it…..and of course the copies on line are not strictly legit.
fuel pump relay
Post by Leslie » Thu Dec 11, 2025 8:06 pm
Some problems just seem to have no answer so well done for getting there in the end :thumbsup: , its fixed now lesson learned , I work with diagnostics regularly on manufacturing equipment at work and not always as easy as a code , problem solving is still needed and a bit of luck at times or previous experience goes a long way.
Your crank sensor was ok so I guess that's why there was no code :D as usually you would get a code for that 99.9% of the time.
fuel pump relay
Post by marti » Sat Dec 13, 2025 5:22 pm
Well done...you got there!....diagnostics are a good thing but they are only a tool at the end of the day like a spanner...and even though you get a code and your kit might give you the part#....it maybe something else down the line....my sprinter van gave me one code for a map sensor and part#....changed that no better because there was another one down underneath the incoming pipe which had failed and sending the wrong signal to the other...wouldnt have found the other one without good ole Google...anyway glad to hear she/he is nearly back burning the Tarmac :D
