BMW X5 4.6is
Apps28
BMW X5 4.6is
Post by Apps28 » Sun Dec 03, 2023 8:39 pm
Hi I have a me X5 4.6is since I change timing chain I have problems all warning lights on dash came on so mechanic said I needed a battery which I changed then all went flat so they said I needed a alternator and then the battery light came on then after that all dashboard light came on then the window wiper when crazy when you turn on back wiper on the front come on and vice averse any help please
BMW X5 4.6is
Post by X5Sport » Sun Dec 03, 2023 9:08 pm
Firstly :hi:
Secondly - was the mechanic a BMW specialist or a main dealer?
Precisely what warning lights are/were on? There are a lot so we need to know exactly which ones. What about the text display in the centre of the instrument cluster - any messages?
Have you had the car error scanned? If so what came up? Without an error code scan you could be chasing ghosts. If this all happened after major engine work, I would go with the electrics being damaged or not connected back up properly.
Apps28
BMW X5 4.6is
Post by Apps28 » Sun Dec 03, 2023 11:17 pm
Hi it’s was normal garage work shop as I stay in canary island there not a lot off choices
BMW X5 4.6is
Post by henrym3 » Tue Dec 19, 2023 9:40 pm
If your battery went flat and then recharged the vehicle will have a multitude of faults stored because of the flat battery which will need cleared before you will have any idea of what the problem is. If these faults happened immediately after the garage work I would be looking at the garage to fix this. If your paying for diagnostics then I suggest you buy a handheld diagnostics tool it will save money in the long run. I had a similar problem some years ago caused by the alternator over charging luckily I had a voltage gauge fitted which showed over 16v. I considered myself lucky I didn’t fry the wiring or an ECU. So check voltage with engine running. Keep us posted. Good luck.
