I've got the small screen head unit in my X5 and in a slightly inebriated fashion I ended up making some daft ebay purchases - one of which was the wide-screen version of the head unit..
Anyway, I attempted to install it the other day and although it works OK it just doesn't quite fit in the arpeture in the dash.
The location screws are in a different place but my dash has square tabs in the bottom corners that would require cutting off which I'm reluctant to do. Also the head unit outer trim is needed.
Should I bother?
Head unit
Head unit
Have a look at this …. It’s from Xoutpost in the US and is for converting a Mk3 Nav to a Mk4 Nav.
https://xoutpost.com/articles/all-bmw/n ... rofit.html
There was a kit offered with brackets, but those have been discontinued. The part numbers are on the link, so you may be able to find some on line perhaps. If not then cable ties are suggested.
