Morning all,
I really should have done something about this at the weekend, but my MOT is booked for tomorrow.
Each time I start the car, I get a warning saying rear fog light failure, however it does work. I was going to change it tonight, but don't have the manual with me, what bulb type is it? 2011 LCI model if it matters
G
Rear Fog Light Bulb Warning - MOT Tomorrow
scz4
OnlineLeslie
Re: Rear Fog Light Bulb Warning - MOT Tomorrow
Its probably water getting in and corroding the contacts on the bulb holder as the seals were a known weak point , mine was popping up the same alarm and when i removed the holder you could see some condensation and the starting of rust in there on my x5. Prise of the little flap on the tailgate and you can remove the holder.
Lights.....assuming it isn’t in the bumper like the X6?
https://www.realoem.com/bmw/enUS/showpa ... Id=63_1221
scz4
Just had a quick look, albeit in the dark, but couldn't see anything obvious, just the close handles. Looks like the entire panel would need to come off. I'll need to take a proper look later.Leslie wrote: Tue Mar 10, 2020 11:32 am Its probably water getting in and corroding the contacts on the bulb holder as the seals were a known weak point , mine was popping up the same alarm and when i removed the holder you could see some condensation and the starting of rust in there on my x5. Prise of the little flap on the tailgate and you can remove the holder.![]()
scz4
Sorted. Removed the bulb and cleaned up the carrier, definitely some water related corrosion, but working now
Hopefully it passes the MOT now.
scz4
Woohoo, passed its MOT, no advisories either. Not bad for a 8.5 year old car with 75k miles.
OnlineLeslie
That's great news and a new gasket is probably needed before the led part of the light get wet and fails
