Trans and diff fluid - How much is needed?
onedaymyfriend
Post by onedaymyfriend » Wed Oct 09, 2019 6:52 pm
Hi guys,
How much fluid will I need for the transmission and both diffs on my 2003 auto 4.6is e53?
I'm planning on using Motul Dexron 6.
Thanks guys.
ttr
Re: Trans and diff fluid - How much is needed?
Post by ttr » Wed Oct 09, 2019 7:52 pm
Eh up,
I did a transfer and diff changes on my 2005, think it’s the same process.
If you do a search on my tag it should bring up the write up and pictures.
HTH
sleepyfolk
Post by sleepyfolk » Wed Oct 09, 2019 11:18 pm
You can get a discount from Cotswold bmw if you message them on here, part numbers below from when I did mine:
TRANSFER CASE
OIL BMW ATF DIII 83229407858 1 Litre
Screw Plug x 2 27111226467
Gasket Ring x2 07119963308
REAR DIFFERENTIAL
Oil BMW Synthetik OSP 83222365987 2 Litre
Screw Plug x2 33117525064
Gasket Ring x2 07119963355
FRONT DIFFERENTIAL
https://www.pelicanparts.com/techarticl ... cement.htm
https://www.pelicanparts.com/techarticl ... lacing.htm
onedaymyfriend
Post by onedaymyfriend » Thu Oct 10, 2019 11:35 am
Thanks guys, I'm going to go the whole hog and get the timing chain guides and tensioner replaced while I'm at it.
Any advice?
Thanks.
Post by henrym3 » Thu Oct 10, 2019 1:34 pm
If your getting the guides done ask them to check the tension of the oil pump chain, it’s adjustable so if it needs doing do it as your hopefully not going to be in there again for 100k. When the sump is off check the oil pick up point/strainer has no debris on it. If it has change it
Post by henrym3 » Thu Oct 10, 2019 1:53 pm
As for transmission I recommend you stick with BMW ATF 2 or use ZF nothing else, it’s expensive but a rarely carried out job. An oil and filter change will require you get 6 ltrs.
dazzasgotav8
Post by dazzasgotav8 » Tue Oct 29, 2019 9:12 pm
i am just curious why the need to change the filler and drain plugs not just fresh copper seal washers .
Post by henrym3 » Tue Oct 29, 2019 10:00 pm
I’ve done 2 trans oil changes and various other things and never changed the plugs, if it has a washer I change that, if no washer just make sure the mating surfaces are clean. Of course everybody has an opinion. If you stick to the correct torque settings there’s unlikely to be a problem
sleepyfolk
Post by sleepyfolk » Tue Oct 29, 2019 11:16 pm
I did mine because they were rusty and I was replacing that much under there it seemed a waste not to!
Nick_Stone
Post by Nick_Stone » Tue Nov 05, 2019 8:10 am
With 136k miles on the clock, and no evidence of my newly purchased X5 3.0d, i'm also looking at having the transmission fluid changed as there are a few gearbox issues going on.
Can the Diff and transmission not be filled with the bog standard red ATF?
Post by henrym3 » Tue Nov 05, 2019 9:19 pm
No No No. Use BMW ATF or ZF. Likewise with the filter. Expensive, but it’s not like you’ll be doing it again soon. Unfortunately you’ve waited till you got problems before changing. If your lucky new oil will cure but don’t hold your breath. Sorry to be blunt. Of course mine is one several opinions you will get/read about.
Post by henrym3 » Tue Nov 05, 2019 9:30 pm
Also read sleepyfolks thread in "problems" as to what was found or not in his gearbox when stripped.
Nick_Stone
Post by Nick_Stone » Wed Nov 06, 2019 1:22 pm
henrym3 wrote: Tue Nov 05, 2019 9:30 pm Also read sleepyfolks thread in "problems" as to what was found or not in his gearbox when stripped.
I'll have a look :)
I'm prepared for a recon box soon, but was rather hoping oil/filter change on it would prolong its life a little longer.
Nick_Stone
Post by Nick_Stone » Wed Nov 06, 2019 1:24 pm
henrym3 wrote: Tue Nov 05, 2019 9:19 pm No No No. Use BMW ATF or ZF. Likewise with the filter. Expensive, but it’s not like you’ll be doing it again soon. Unfortunately you’ve waited till you got problems before changing. If your lucky new oil will cure but don’t hold your breath. Sorry to be blunt. Of course mine is one several opinions you will get/read about.
Cheers for you reply.
I've only had the X5 a few weeks. Nothing in the documentation that indicates any form of servicing on the gearbox.
Blunt is the best way! :)
Post by henrym3 » Wed Nov 06, 2019 9:00 pm
Be careful who you get to do the g/b oil change if not doing it yourself. There’s a thread going at the moment on the e70 forum of someone getting an indie to do his oil change and it came back with not enough oil in it. A clear indication that they didn’t follow the correct procedure. Choose carefully and ask questions, if they get the hump at being questioned, go elsewhere.
