so I have resorted to pulling out the big 50 amp fuse
venting fan won't switch off
- Powercat
My interior venting fan is not switching off even after 30 minutes when the car is locked up, I have tried disabling it by selecting the venting mode on the computer and switch it off, no luck when I switch the ignition off it is still running and if I leave the car for an hour or more the battery nearly goes flat
is this common ?
02 x5 3.0d auto cat D
- kena
Re: venting fan won't switch off
Sounds like the heater final stage resistor ( hedgehog resistor ) is knackered.
Plenty of threads on outpost.
One of these
http://bmwpartsonline.co.uk/Product-1304
One of these
blingsta
well known for killing batteries !!!
- Powercat
[quote=""kena""]Sounds like the heater final stage resistor ( hedgehog resistor ) is knackered.
One of these
http://bmwpartsonline.co.uk/Product-1304[/quote]
Many thanks for the heads up and link
at least I know how expensive they are, any idea on the location as I do all my own repairs ?
On ebay £28.99
http://cgi.ebay.co.uk/BMW-HEATER-BLOWER ... 9397230110
One of these
On ebay £28.99
- Sanj
As long as it is OEM then fine - don't get anything else.
Located behind aircon - below satnav. Footwell panel, etc... Fiddly, as usual...
- Black X5
Probably worth giving a Land Rover dealer a call- the FSR on the L322 Range Rover (2002 to 2004) is identical- and I believe about 2/3 the price compared to the BMW dealers. (identical part, from identical manufacturer, just in a an LR box!)
As Sanj said- stick to OE- anything else could have potential safety issues (worst case thinking along the lines of shorting out and causing a fire)
E70 3.0D SE, Black with Black - Gone but not forgotten! >:D
This should help too.....
http://www.xoutpost.com/attachments/x5- ... fsruk3.pdf
And this.....
http://www.xoutpost.com/bmw-sav-forums/ ... drive.html
And this.....
Never anthropomorphise computers. They hate that.- Powercat
[quote=""Sanj""] Located behind aircon - below satnav. Footwell panel, etc... Fiddly, as usual...[/quote]
Okay looks like I'll need my very big hammer then
Once I dug it out hopefully I will be able to confirm if it has blown.
Thank;s X5Sport
Those pictures in the pdf are fantastic and easy to follow, I hope I get the problem solved in the next few days
Thank;s X5Sport
- lezmtaylor
You won't see if it is ' blown' , just make sure you replace with the updated version.
- Turks
- Contact:
As Lez says, you won't see anything wrong with it... you just need to replace it and make sure it is with the new version.
Turks.
Turks.
Present:
Past:
Past:
- Powercat
It took me about 25 minutes, looking at the old one there is indeed no sign of a problem, as the new one has a different type of caseing to the old one
I presume it is the updated version, anyway I'm very happy it is all back to normal, many thanks to everyone that helped
- ITBarbie
Well done Powercat. Was it a tough job? By the sound of some of the stories related to access I would rather lay on a live hedgehog than fit one for the X !
2004 Sapphire Black 3.0d SE
MODS
MODS
- Powercat
Hi ITBarbie
I found it an easy job, the pictures posted by X5Sport where a big help and I have always repaired my own cars,
so I am used to getting my hands in tight places
as for hedgehogs
anywayI guess it's a story of horses for courses
- ITBarbie
Well what can I say but well done. You can do mine when it goes! Lol
MODS
MODS
- pvr
You have a facelift Barbie (hmm, sounds a bit odd ..), so your hedgehog should not go ...
911 50th anniversary -
