Drivetrain issue
Sirrepairalot
Drivetrain issue
Post by Sirrepairalot » Fri Apr 12, 2019 12:31 pm
Hi folks,have a problem when accelerating,it feels as though you driving over the cats eyes in the road sort of thing.it gets worse the harder you accelerate.also it only seems do do it when car is warm.it did inform me on impa a while back about the transfer case oil needs changing,just ain’t had a chance yet.do you reckon it’s the trans case on the way out or what.
Re: Drivetrain issue
Post by Themoog2 » Sat Apr 13, 2019 9:30 am
Torque converter shudder. Get the transmission fluid replaced and stick in a bit of Dr tranny.
Sirrepairalot
Post by Sirrepairalot » Mon Apr 15, 2019 10:57 pm
Already changed mate.also have trans failsafe on the dash now and again
Post by X5Sport » Tue Apr 16, 2019 9:46 am
Get a code read done. Bosch Autocentre’s have the right software as do BMW Dealers. Could be an iffy servo, crud in a channel, slipping clutch or brake-band under load or transfer box, or even something engine side causing uneven firing under load (injector, MAF, sensor). If the warning is illuminating at least there’ll be a log record.
