Parking sensors
Parking sensors
Both my front and rear parking sensors have suddenly stopped working.....the green light on the button still glows continuously and there is no beep as you get when an individual sensor goes down. tested with a snap-on scanner and its says everything ok. manual test of the acoustic sounders using the same scanner also works fine......anyone any ideas???? its a 2006 3.0d
- marti
Re: Parking sensors
It could be a faulty PDC Module....unusual for all the sensors to suddenly stop working.
- Alan Gunn
Re: Parking sensors
Snap-on scanner once told me i had a bad coil pack on cylinder 8 causing misfire.
Problem was it was an Audi v6tdi.
Can you get it scanned with bmw kit just in case.
Re: Parking sensors
yes...that was my thoughts, but I thought it would have thrown up the blinking light and tone on the switch. co-incidentally when I took out the pdc module for a quick visual check and spray with contact cleaner, the battery box had about an inch of water in itmarti wrote: Sat Feb 23, 2019 8:40 am It could be a faulty PDC Module....unusual for all the sensors to suddenly stop working.
- henrym3
Re: Parking sensors
How does water get in there, the container is made of rust free plastic. There is a mountain of electric bits in there
Re: Parking sensors
that was my next question after I spent 10mins looking for a drain hole....can only think that something must have spilled in the boot but I have never noticed anything. it has the hard liner fitted so I think I would have seen something......
- sleepyfolk
Re: Parking sensors
Check in the corners where the lights are, could be the gaskets around the light lens
