E53 AIR FILTER
X5Andym
E53 AIR FILTER
I am thinks of fitting a performance Ramair air filter to my E53 4.4 petrol, has any one done the same, is it worth doing or not.. read a bit about it.. still open to advice please..
Thank you very much
cheers
Andy
Thank you very much
cheers
Andy
- lezmtaylor
Re: E53 AIR FILTER
I fitted a K&N oil charged filter to my 2002 4.4 (with lpg) in 2007, recharged it once, it seems to do the job ok.
dazzasgotav8
Re: E53 AIR FILTER
are we talking about a performance panel filter to replace original or a cone style filter to replace the original box
- lezmtaylor
Re: E53 AIR FILTER
It fits in original filter casing.
X5Andym
Re: E53 AIR FILTER
[quote=dazzasgotav8 post_id=169176 time=1550953622 user_id=6156]
[/quote
A panel foam filter similar to a K & N..
Andy
[/quote
Andy
dazzasgotav8
Re: E53 AIR FILTER
over the years with messing around with filters i have settled for just buying a good quality paper one now, for my x5 i use nothing but mann filters which is what bmw use anyway and always buy them using the mann part number rather than for a specific vehicle as then you avoid the good ole bmw mark up factor ..
- henrym3
Re: E53 AIR FILTER
Had this fitted for 3 years now,
- staffordcox
- Contact:
Re: E53 AIR FILTER
That looks awesome!! Does it improve the sound too?
- henrym3
Re: E53 AIR FILTER
It sounds pretty normal in day to day driving, but when you put your foot down everybody knows you have. I have kept the normal pipe that takes the outside air to the standard airbox and it now puts outside air into the area that the CAI draws in.
There’s lots of debate about drawing hotter/cold air in and I monitored air intake temperatures at the AFM before and after conversion. After 20mph the temperatures were the same and below 20mph and idling/traffic jams the temperatures were 2/3 degrees hotter.
