X5 se and sport suspension heights
Emigrant
Post by Emigrant » Sun Oct 07, 2018 2:31 pm
Hello guys I've searched the web and not really found an obvious answer.
I have a 3.0d se with sport suspension and seats etc, according to the VIN check.
Looking at previous MOT the front springs have been replaced. Looking at the car the front arch gap is about 1 inch bigger than the rear.
So is there a height difference between se and sport suspension?
Has my car had SE replacement springs? Or has the rear been lowered?
Rear has standard non adjustable links. Rear works fine. Got new AMK compressor fitted.
Cheers Grant.
snrbrtsn
Re: X5 se and sport suspension heights
Post by snrbrtsn » Sun Oct 07, 2018 4:29 pm
Should find the front axle height here
https://workshop-manuals.com/bmw/x_seri ... eight_e70/
Rear axle height here
Graeme
Post by Graeme » Sun Oct 07, 2018 4:59 pm
...and just be sure to make measurements on flat level ground as any slope makes quite a difference!
Graeme
Emigrant
Post by Emigrant » Sun Oct 07, 2018 5:35 pm
Hi thanks for the reply I will measure the gap when I get a chance.
But that only gives me one distance for each wheel.
So are the heights from se and sport the same then?
Emigrant
Post by Emigrant » Sun Oct 07, 2018 6:01 pm
Cheers looks mine is low on the rear.
I have 20" wheels steel spring on front and rear bags, both heights should be 732mm. I have 742mm front and 705 rear. So wrong springs on front and lowered on rear  :o
Think I'll make some adjustable links for the rear and Jack it up.
Groken
Post by Groken » Sun Oct 07, 2018 9:39 pm
You can calibrate rear suspension.
Emigrant
Post by Emigrant » Sun Oct 07, 2018 10:22 pm
I have INPA but don't know how to do that.
NehalX5
Post by NehalX5 » Tue Oct 09, 2018 11:35 am
I believe there is no difference in height, as according to the brochure from 2009, option 226 (Sport suspension), which is included in option 330 (M-sport package) has no difference in ride height.
BMW E70 X5 3.0sd | M-Sport | 7 Seats
Audi A6 C6 3.0TFSI Quattro S-Line tiptronic
Citroën C1 1.0 VTR
BMW E39 528i SE Manual
Emigrant
Post by Emigrant » Tue Oct 09, 2018 7:16 pm
Ok thanks for clearing that up. Don't know to if to buy lowering springs or raise the rear now.
Think it will be too harsh low.
snrbrtsn
Post by snrbrtsn » Tue Oct 09, 2018 7:44 pm
S815A Poor Road Package ?
That adds thicker Spring pads which could explain your anomaly
Emigrant
Post by Emigrant » Wed Oct 10, 2018 5:44 pm
Oh I'll check that out.
