enabling auto locking of doors...
Any one know the sequence of buttons n stuff to enable the auto lock function please ?
- Greydog
Re: enabling auto locking of doors
When I changed mine I used BMW 1.4 in IKE (IIRC) reprogram opens a series of tick boxes you can select what speed it occurs at. There are many other functions you can adjust as well.
Hope that helps
Hope that helps
From memory it was a dealer coded function at the time, along with getting the seat memory to note other settings such as mirror position. I had to take mine in and fill in a form selecting what ‘convenience’ options I wanted coded in. Carly might also enable it if you have that.
- Alan Gunn
BMW scanner 1.4 for me as well.
You can do quite a few things with it including turning the hot/cold light check off if you want to use LED's.
You can get it for not a lot on the bay.
Not the advert i bought from just a quick search.
https://www.ebay.co.uk/itm/V1-4-Diagnos ... SwL1ZalOYY
As others have stated it’s easy enough to do using scanner 1.4
It’s worth getting as it’s nice and straight forward to use and navigate.
Hi Raj,
I have one of these, but never got round to installing it...
I will dig it out this weekend n& give it a go.
Will this package also pinpoint a potential auto leveling issue cause if a potentiometer height sensor is iffy?.
Hi Raj,
It should do as I’m sure I’ve had errors for a specific sensor previously.
Hi Raj,
