Ignition leads (cables)
X5Andym
Post by X5Andym » Sat Jun 02, 2018 10:13 am
Hi ALL :)
E53 4.4 2005, (37.000 miles)
Help please.. had a few starting issues of late.. :( (also cut out me at a set of traffic lights this morning and when restarted was misfiring.. did get started ok and got home..  :) so looking to solve the problem, going to change the ignition switch, fuel filter, spark plugs and also the ignition leads (cables) please can you recommend the best ignition leads to buy..
Any one had the same starting problems which may need a different fix  O:-)
Thank you for any help
Andy
Re: Ignition leads (cables)
Post by X5Sport » Sat Jun 02, 2018 10:19 am
You have coil packs on each plug, not HT leads.  £25 - £50 each depending upon manufacturer.
http://www.realoem.com/bmw/enUS/showpar ... Id=12_1104
You will probably be better off running diagnostics to see what errors are being reported as it might not be ignition.
Post by henrym3 » Sat Jun 02, 2018 11:13 pm
I'll put my money on it being the AFM with  the symptoms you describe
A Blair
Post by A Blair » Sat Jun 02, 2018 11:37 pm
Diagnostics would be a great starting point.
You could be wasting money replacing stuff that is not broke.
X5 E53 2005 4.4 Sport. Toledo Blue
Things to consider.
Radio. (something in
Detail Car.
