Driver’s seat height adjustment
Hi - I pushed my seat back after my vertically challenged GF had driven, but I’d left a mini tool box under the seat. (I used the memory function, so it also tried to lower it etc). Needless to say the seat got jammed, but I managed to pull the box out... now the seat height won’t adjust. I can hear the relay clicking but that’s it. Front portion of the seat will raise and lower - but rear portion won’t and my GF can’t see over the steering wheel now....
Grateful for suggestions as to what to check, as I can’t easily raise the seat to peer underneath...
- henrym3
Re: Driver’s seat height adjustment
I would remove the 4 screws that bolt the seat to the floor and then tilt the seat back wards and see if you have damaged any of the wires or pulled a plug out of it's socket. First try and help the seat up as you operate the switch.
Yep. I think that’s my first port of call. Might plug it in quickly to see if any seat errors - may have messed up end point settings - but perhaps a wire’s come loose... thanks for the reply!
Beware of tripping the airbag warning though! Assuming you have the seat ones.
- sleepyfolk
If you whip out fuse 44 (check the number - that’s from memory!) you can have the ignition on etc and use the electric switches on the seat without getting an airbag warning light problem
Mercedes CLK 320
Audi A6 Quattro 2.4
Mercedes CLK 320
Audi A6 Quattro 2.4
Quick update, as I finally got round to looking at this... I’d damaged the plastic terminal plug mounted to the motor - and in fact, snapped one of the terminals. Was able to Heath Robinson it with a spare bit of wire to move it back to position for my GF (who’s had to sit on a cushion to see over the steering wheel!) - and will see if it’s possible to solder a bit of wire to the terminal and use bullet connectors or similar...
glad you got sorted bet your GF is more happy
05 , 30d Le Mans Blue Sport
... she’s less un-happy....!
Or change the girlfriend to a taller one
If in doubt, and all else fails - read the instructions!!
Current car : 2004 E53 X5 3.0D
