Tank Ventilation Valve
- jason1872
Hello guys i've just replaced the ccv in my 02 3.0i i now have error 68 Tank Ventilation Valve error with the EML on i've replaced the valve but still get the error,i have found a plastic pipe under the manifold next to the valve that doesn't seem to attach to anything this pipe has a bend in it and points inwards towards the manifold,on checking the plug that goes onto the valve the plug has only 1 female pin and the valve has 2 males pins,any help would be much appreciated.
- henrym3
Re: Tank Ventilation Valve
My understanding of the vent valve is there are two pipes one in from the tank one out to throttle body and ecu cycles the valve. Mine has a 2 pin plug 2 male pins on the valve and 2 female on the lead/plug
- jason1872
Thanks for the info,turns out i had managed to miss a connector and was lying behind the loom but i now have a spare connector with 1 female pin inside lying spare any idea where it should be?
- jason1872
All connected now,missed the oil pressure sensor.
