Oh the joy
Oh the joy
Post by henrym3 » Mon Jan 29, 2018 8:10 pm
Of getting to the valley pan, apart from replacing it all the other parts that now have to be replaced when there’s nothing wrong with them but you have to do it cos you don’t want to go back there. My sons X but I have a question, on the end of the injectors there is the O ring, then there is a plastic push on piece presumably to ensure the O ring comes out with the injectors this part is not listed in the parts catalog. Most are broken/cracked. I assume they’re not an essential part???Image
IanP
Re: Oh the joy
Post by IanP » Mon Jan 29, 2018 8:57 pm
Cant answer your question, but if your in that far it might be good to change the hoses at the rear of the engine. Its a b*gger when they let go
Ryoken
Re: Oh the joy
Post by Ryoken » Wed Jan 31, 2018 6:18 am
i think these are the parts your referring to
http://www.realoem.com/bmw/enUS/part?id ... 3531274729
me personally id replace them
oh, and i used my model of shed on realoem
2002 e53 4.4  tempremental
Re: Oh the joy
Post by henrym3 » Wed Jan 31, 2018 4:31 pm
No definitely not that part, when you look at the bottom "O" ring (No6) it fits under it, there is a groove in the injector for the plastic piece to fit into. As the part isn't listed I assume it's not that important, just means the "O" ring will stay in the inlet manifold rather than on the injector after removal.
IanP
Done good advice
Ryoken
Re: Oh the joy
Post by Ryoken » Thu Feb 01, 2018 5:25 am
fair enough :)
i just saw plastic clips ;)
