Smoke from under car
Today noticed white smoke lots of it for approx 10 seconds coming from a small exhaust pipe under the passenger side any ideas what's causing this
And am I right in thinking this for aux heater
- Steamyrotter
Re: Smoke from under car
Yup
Thats it
Thats it
Please note...
Please note...
Any idea why it was smoking?
It has to warm up, and the same as the car exhausts will steam for a while, the aux heater does the same.
Should it smell of diesel
- Steamyrotter
They will smoke especially if there is unburnt fuel left in the system after shutdown, or failure to ignite.
I inadvertantly "tested" my fuel pump and filled the thing with diesel...
Lost the car in the plumb for a bit and then finally found it again....
Quite impressive smoke screen but not for the weak hearted!!!
Please note...
Please note...
Ive noticed smoke coming from under the passenger side of my car a few times now after I turn the ignition off. I assumed it was something to do with the auxiliary heater, but Mrs Lyons nearly had a heart attack when she saw it at the weekend so I thought I should just check what the story is with it!
Under what circumstances does it smoke, given that it doesn’t happen every time? Is the auxiliary heater something that works all the time- it can’t be turned off etc? I have no idea what it does! If it makes a difference, I dont even have the timer set to come on :hmmm:
Almost certainly your Webasto auxiliary coolant heater running.
It burns diesel and the exhaust is where you are seeing smoke. It will take a few moments to fully fire up and might smoke (or steam) whilst it does. You should also hear a steady clicking noise whenever temperatures fall below 5°C. It runs automatically.
It’s there to bring the coolant temperature up much faster on diesel vehicles in very cold weather (which you probably knew) and can also be upgraded to provide additional heating on demand. That functionality was the extra option and adds a remote key fob that allows you to toggle it.
Very informative thanks. I didn’t realise it came on automatically below 5 degrees. I have also heard the clicking but assumed it was the climate control so always just turned it off before it blew up!
Do all cars have the timer option, or was that the extra? If the latter, should it have come with a remote? My car has the timers, but no remote.
The timer option applies to the cooling system - I can’t remember what it’s called now but something like Aux ventilation? That was standard across the range I think if you had climate control rather than basic air con. It is supposed to get the hot air changed out just before you get in the car (as long as the battery is OK). No remote, just settings on the screen.
Ok, cheers. The bottom line is there’s nothing wrong with my car, so I can relax!
I can set mine to come on in the morning so car toasty hot
- Alan Gunn
Don't forget it also uses the battery so make sure it is a good one and well charged up.Thegolfking wrote: Wed Jan 19, 2022 4:22 pm I can set mine to come on in the morning so car toasty hot
