Shuddering........`
Shuddering........`
my cousin has Just bought a 55 X5 3.0Diesel, having a few problems with the car shuddering while going between 65 - 75 mph.
I've had the tracking, balancing and wheel alignment all done but it still shudders, also happens with the cruise control on and off.
thanks
thanks
Re: Shuddering........`
What condition are the tyres and rims in? Any dents, nicks, unusual wear on the tyre treads?
What happens if you gently hold the steering at this speed - in a safe area of course - does the wheel wobble gently?
There is a bit of a nick out of a rear alloy but all tyres are pretty new.
If I hold the wheel gently it shakes quite hard, tends to be worse going up or down hill.
Sounds like the balance is still off to me, unless you have a bent wheel rim.
Your discs could be warped but it may also be worth checking your wheel bearings!
Another thing to check could be your track rod ends.
- x555
If the shudder is under braking then i would say discs.I have recentley noticed a shudder under braking at higher speeds and after an investigation on the weekend i need new pads and disks
.......... oh well more money more parts the car is starting to show it's mileage at the moment and has cost a small fortune lately.The price we pay to maintain our precious x's i suppose
- bullethead
[quote=""X5Sport""]Sounds like the balance is still off to me, unless you have a bent wheel rim.[/quote]
I agree sounds the same as mine and mine is a wobbly wheel..same speed aswell. Have you tried swapping a wheel at a time to see.
- x555
[quote=""bullethead""][quote=""X5Sport""]Sounds like the balance is still off to me, unless you have a bent wheel rim.[/quote]
I agree sounds the same as mine and mine is a wobbly wheel..same speed aswell. Have you tried swapping a wheel at a time to see.[/quote]
That will be them pram wheels again then
- bullethead
- Sanj
Yeap, mine are staggered and directional...
Can't swap em round.
Feel free to punch me bullethead at the Meet.
- bullethead
[quote=""Sanj""]Yeap, mine are staggered and directional...
Feel free to punch me bullethead at the Meet.[/quote]
I'm gonna print this and bring it with me........
Stick your staggered up your arses. I've got 20's and snow socks that fit all 4
And a proper engine, none of these trucks and tractor shite
- bullethead
Oh and what about the spare....Don't need to cane it for long, just enough to see if it still shakes your fillings out.
I had shuddering around 60 and much more pronounced under braking. Was the thrust arm bushes. Car has only done 70K and its a well documented and common problem on the E53.
Jay
Jay
