Ac wasn't working...out of gas.
Just had it recharged and about an hour later the driver side is starting to come out warm and the centre is passenger is cold but not as cold as before.
I knew there must be a leak before I had it regassed and I informed them. The did a leak test with a dye and all was well.
Sent from my SM-G900F using Tapatalk
Ac issue
pcdee
Re: Ac issue
Quick update.....lost all ac.
Surely must be a leak
X5 E70 3.0D SE
Re: Ac issue
Sounds like it. Needs a better dye test done. It might be coming from a tricky to get at position. Though if it is losing gas that fast it should show up easily enough now. A simple pressure check by them will show whether it is holding and if not then they need to look for it.
pcdee
Re: Ac issue
Update.......leak in the condenser.
Anyone know the part number?
X5 E70 3.0D SE
- Alan Gunn
Re: Ac issue
Put the lats seven of your VIN number in here and find every part number you will ever need.
http://www.realoem.com/
pcdee
Re: Ac issue
I have found the part number through Realoem....thanks
Looks like there are different sizes for the condenser depending on what make u go for.
Would they all fit?
Would they all fit?
X5 E70 3.0D SE
