AC compressor thingy not spinning
diluxe
The wife noticed that the x5 wasnt blowing out ice cold air , i took it down to the local ac specialist who checked the gas in the system and said it was fine . He had a look around the engine pointed to the compressor and said the end bits not spinning and it needs to go on diagnostics .
Is there anything i can check myself before spending the cash on a dignostic check?
Re: AC compressor thingy not spinning
diluxe
Thanks . Anyone with anything more specific such as location of relays , I found one mention of a relay in Google in the o/f/s wheel arch but not sure if that's accurate , also the climate control in the dash is all working so i assume power isnt an issue but how to check its getting to the compressor unit?
roycas
My compressor wasn't spinning, when the AC was on, because the drive belt had snapped !!
As your gas pressure has been checked OK, the next thing is does your aux fan (the electric one) turn when the a/c is switched on? If it doesn't then that will also shutdown the compressor. These fans are not a simple fix as they run on a pulsed signal, not 12V DC.
diluxe
AUX fan checked out OK, all belts in place, what next?
- Alan Gunn
Not the same car but my e46 had a similar problem and it was down to a pressure switch on the pipe.
A case of locating it and then unscrew and replace with new one and no gas lost.
diluxe
So got hold of a cable and had the error codes read I have the following
JBBF Error code A72F kind of error 64
JBBF Error code 9C5E kind of error 21
DME/DDE Error code 4A4F kind of error 61
Does anyone know is how to decipher the above or where in INPA I go to find out more ?
diluxe
bit more digging found the following
- Alan Gunn
[quote="diluxe"]
diluxe
lets try that again
translated
1st error
Magnet coupling air compressor. No signal or value. Test conditions. Error present and already saved. Error did not light up a warning lamp
2 error
Pressure sensor
"Signal or value above threshold. Test conditions. Error not present, but already saved. Error did not cause a warning lamp to light up"
translated
1st error
2 error
Pressure sensor
- Alan Gunn
Pressure sensor was the problem i had on the e46.
Air compressor is that for the suspension or the air-con.
Can't see the screen shot very well but that's just me lol.
diluxe
Swapped the sensor out cleared the codes down and the compressor is still showing an error, so looks like I'm going to have to give it in at an indi ........
diluxe
gave it in at the local "BMW" specialist and they advised the compressor has gone
