Alternator removal!
kennyfin73
Alternator removal!
Post by kennyfin73 » Sun May 14, 2017 11:58 am
Anybody removed or have info about removing an alternator. Cant get it out, am guessing I may have to take out the radiator! Must be an easier way surely!
X5 2003 3.0D (184bhp)
Steamyrotter
Re: Alternator removal!
Post by Steamyrotter » Sun May 14, 2017 1:30 pm
Its a manifold off job minimum.
Whats the issue?
It could just need a regulator change which can be done in situ.:-
http://xdrivers.co.uk/forum/index.php/t ... #msg126471
Please note...
kennyfin73
Post by kennyfin73 » Sun May 14, 2017 7:25 pm
Not charging battery. Doesn't sound to healthy and nearing 180k miles prob be best to change out whole unit. Having taken off belts and checked alt it seems to be smooth enough, unless noise coming from worn bushes in regulator.
Post by henrym3 » Sun May 14, 2017 7:38 pm
Having just read Steamyrotter's article surely it's got to be worth trying his solution if only about £22. I never see above 13.6/7v coming from my alternator, should I be worried.
Steamyrotter
Post by Steamyrotter » Mon May 15, 2017 1:09 pm
13.6/7 is OK depending where you measure it!!
ideally you want 14 - 14.2 at the under bonnet charging points as it is a long way to the battery..
And the high charging current will cause a volt drop along that cable.
Please note...
Post by henrym3 » Mon May 15, 2017 1:16 pm
That's the voltage that shows up on the OBC
Smeeagain
Post by Smeeagain » Mon May 15, 2017 1:44 pm
So where does the OBC take it's reading from ?
Smee
Post by henrym3 » Mon May 15, 2017 7:09 pm
Not got a clue but would assume it is from somewhere that gives an accurate reading of alternator output. There again one should never assume.
Steamyrotter
Post by Steamyrotter » Wed May 17, 2017 9:39 pm
unfortunately the OBD is not the most accurate measurement.
You need to use a decent multimeter on the charging points
Please note...
dark_stranger
Post by dark_stranger » Wed May 17, 2017 9:45 pm
You don't need to take the manifold off, I replaced my alternator when I first got the car and you need to remove the fan, but once that is off it comes out.  I had to buy a special tool (£20'ish) that holds the fan clutch/motor whilst you undo it.
kennyfin73
Post by kennyfin73 » Thu May 18, 2017 8:26 pm
It was necessary to remove the radiator to get the alternator out!! Lets hope the O rings on the hoses seal again. Anybody know the sizes of these?
Post by henrym3 » Thu May 18, 2017 9:16 pm
Any time I've had them off I've very lightly greased them with either vaseline or silicone grease so they slide back on easily and never had a problem with them leaking
kennyfin73
Post by kennyfin73 » Tue May 23, 2017 8:29 pm
Job all done with no leaks at cooling hoses.
Ordered a STARK (£50) alternator and a Valeo came. Guessing its a refurb unit but none the less it is in very good condition. Replace gearbox oil cooler as well as noticed some oil weeping from oil side of cooler.
