Reverse camera
Matthew riseborough
Reverse camera
Post by Matthew riseborough » Sun May 29, 2016 9:32 pm
Hey
I am new to this forum so am looking for some help.
Today I fitted a reverse camera to the BMW one for which I had to remove the rear number plate lamp which I done and wired the new light and camera all in and all works fine but now I have a message come up saying I have a plate light out is there a way of getting rid of this?
jonsteele
Re: Reverse camera
Post by jonsteele » Sun May 29, 2016 10:33 pm
Is the new bulb an LED? If so it won't be pulling enough current for the car to detect, it then throws an error. If it is an LED, you need to get a CANBUS error free version (cheap enough on eBay). If it isn't, I've no idea.
Sent from the dark side by the power of the force!!
Matthew riseborough
Re: Reverse camera
Post by Matthew riseborough » Mon May 30, 2016 9:49 am
Unfortunately I can't find a canbus one.
This is the reverse camera I installed
http://m.ebay.co.uk/itm/Car-Rear-View-R ... nav=SEARCH
I have read somewhere that the 1.4.0 software can turn off this light is that true?
TheHerd
Re: Reverse camera
Post by TheHerd » Tue May 31, 2016 10:05 pm
Yes you can turn off the numberplate bulb check with the BMW Scanner 1.4, I've done mine.
2006 BMW E53 X5 4.8is Le Mans Blue
Purchased Dec 2025, work in progress...
(SOLD) 2006 BMW E53 X5 3.0d MSport
20mm Spacers | LED Interior Lights incl NPlate | HID kit | M-Tech Steering | Upgraded AMP | Remap | LED Tails | LED Repeaters | Subwoofer |
fenj66
Re: Reverse camera
Post by fenj66 » Wed Jun 01, 2016 9:57 am
that looks like the same camera i installed.
i fitted mine next to the number plate light so didnt need to recode the car.
robsey29
Re: Reverse camera
Post by robsey29 » Wed Jun 01, 2016 7:14 pm
Does this come up on the sat nav screen when you select reverse? also how is it wired in?
fenj66
Re: Reverse camera
Post by fenj66 » Wed Jun 01, 2016 9:13 pm
[quote="robsey29"]
It's all been covered before. Use the search facility and look for reverse camera install.
