Towing Mirrors.
Barry-C
Towing Mirrors.
Has any body found any caravan towing mirrors that fit the F15 X5 The ones that I have used for years don't fit, the glass is too close to the mirror housing, and the edge of the housing has got a sharp chamfer up to the glass. I have checked with BMW, they do a mirror for the F15, but they want £129.00 EACH for them, hence I am looking for alternatives.
- allforus
Re: Towing Mirrors.
Hi I have been using the millenco aero 2 mirrors, they are fine but you need to fit the clips first then thread the bar through.
I over tightened one side and cracked the mirror case I have since removed the mirror cap and fitted a strengthening bar under the edge of the mirror on both sides and all is well.
I tried loads of different mirrors at the caravan dealers and they where the only ones that fit and fit top side only
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
Mfosbrooke
Barry-C
Re: Towing Mirrors.
I purchased a pair of genuine BMW F15 X5 mirrors from Cotswold BMW, Gloucester. I was still unhappy with the way that they fitted, clamped to the lower edge of the mirror housing, so I have added the rubber straps from my old towing mirrors which makes the fitting much more secure. these straps pull the mirror onto the mirror housing, the free end being anchored with a small rod that engages under the clamping screw heads.
Mfosbrooke
Re: Towing Mirrors.
Looks like they don't sell the BMW mirrors anymore can't find any one who stocks the product code and the dealers can't find them on the system anymore.
BMW X5 F15 MSPORT 2016
Re: Towing Mirrors.
Had a quick check in Realoem and there is certainly nothing showing on the latest database, unless it has been put somewhere very obscure.
Jasonwhitt
Re: Towing Mirrors.
[quote="allforus"]
Jasonwhitt
Re: Towing Mirrors.
Where did u get strengthing bars from ?
- allforus
Re: Towing Mirrors.
Hi the bars are made from the locking pins from an old set of big foot caravan they fit perfectly under the lip at the top of the mirror with just a slight trimming
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
Barry-C
Re: Towing Mirrors.
My mirrors came from BMW Gloucester and were £120.00 ish, very well made but over priced and not worth the money, but they fit. To prevent possible loss I have fitted the rubber strap that was on my previous mirrors, that now hooks over the top of the mirror housing, and locates with a small bar over the fixing clamp screws.
