Oil level to high
rob
Oil level to high
Post by rob » Wed Mar 23, 2016 2:12 pm
Whilst checking I drive my car is showing oil level too high but when checking dipstick level is slightly below maximum could it be sensor
Re: Oil level to high
Post by X5Sport » Wed Mar 23, 2016 3:12 pm
It could.  I have had this too and the dealer drained a small amount even though like you, the dipstick says fine.  Not had the alert since.  The Dealer accused me of overfilling it and then had to apologise when I quietly pointed out that all servicing was done by them!
rob
Post by rob » Wed Mar 23, 2016 5:58 pm
They did take some oil out and replaced a pulley and fan belt said would reset after twenty miles but didn't looks like it will be a new sensor
Post by Horizon » Wed Mar 23, 2016 6:13 pm
[quote="rob"]
[/quote] my 3 series has not got a dipstick at all, only the sensor . Crazy in my eyes
Riggie
Post by Riggie » Wed Mar 23, 2016 7:07 pm
My previous F10 528 and current E70 are fitted with these crappy oil level sensors. Luckily, both had/have a dipstick as well and in my experience, these things are not very accurate.
99ron
Post by 99ron » Thu Mar 24, 2016 3:27 pm
Yes the idrive reading on mine is usually slow to catch up so don't rely on it for oil changes.
If you correct it using the dipstick reading (a pila pump is good for removing some excess oil) and it reoccurs then it could because the DPF regens are failing. I read this dumps the unburnt fuel for the regen into the sump apparently. Regen failures are often due to thermostat issues not allowing the engine to reach 75C.
3.0SD E70 M Sport.
Z4MR E85
rob
Post by rob » Thu Mar 24, 2016 4:04 pm
They checked dpf was replaced six months ago and the car gets to 93degrees all the time and goes to 105 degrees when doing a regen . The dealership replaced the control unit and all the glow plugs when they did dpf thermostats were also done all done under bmw auc warranty
rob
Post by rob » Thu Mar 24, 2016 7:04 pm
They kept it three days to do some software updates and a recall on pulley with new fan belt
rob
Post by rob » Fri Mar 25, 2016 6:18 pm
Got car back checked hidden temps got to 97degrees and stay there for hour half cars seems to drive better after software update and mpg has gone up
