My manifold dilema with pics!!!now updated and fixed!
x555
Post by x555 » Mon Jan 17, 2011 11:23 pm
I’ve been a little busy over the last few days with the x so I thought I would share my experience with you.
As some know already I recently changed the glow plugs and control unit which was a bit of a job to do :roll: as the car wasn’t starting right (firing straight away and then cutting out).That sorted out that problem but another starting issue arose in the fact that it would turn over/crank for a while before finally starting(opposite symptoms to before).
A diagnostics scan revealed that I had the warning error ‘Plausibility rail-pressure volume regulated’.
I posted on here and x5outpost and I was told by powers1 on there that the most common issue with that error is the rail pressure sensor.
I had seen this error before and thought it was due to the other issue but not to be the case.
So before replacing the rail sensor I thought I would get the car in the workshop, take a few parts back off and have a good look around to see if I had disturbed a hose or something whilst doing the previous job thus creating a new problem.
I had a good look around but couldn’t see anything obvious so I thought I would start it up and re check everything(especially as the rail sensor costs about £180 :o .
On starting it up I noticed smoke under the bonnet especially when pressing the fast pedal.
I had also noticed a small amount of smoke previously when the car was outside but put it down to a cold morning and possibly the webasto fumes blowing around. This accompanied by mrs x555 complaining about fumes led me to examine the exhaust manifold.
Ironically I had previously used Nige’s cracked manifold thread for pics etc to aid me with the glow plug job and so checking it again (thanks again Nige :thumbsup: )I half inched one of mrs x555’s travel mirrors and took a look only to find this…..(better add some pics now as I‘m starting to waffle :lol: )
A crack in the manifold ( :cry: )
Which then meant removing loads of parts…..
Than removing the inlet manifold…again…along with the injectors and fuel lines etc…
Parts beginning to pile up now….
Then onto the hot film air mass meter (or maff sensor as I think it’s commonly known) various fuel lines and hoses to shift accompanied by the rocker cover and it’s (what seemed like) one million bolts :lol: including the small one at the back which Nige warned about in his post.(the one when listing parts etc when they came of I called the bast@£d)
Maff sensor….
Rocker cover….
Along with all the soot/exhaust fumes….
Which finally revealed the exhaust manifold along with more black soot everywhere :roll:
I could then undo the manifold from the head, turbo and egr pipe which left this …..
And revealed not only the crack I spotted with the mirror but more :o …
So it was decision time….Buy a new manifold or repair the old one if possible :scratchhead:
I went with the latter due to a new manifold costing £350 :o and gave my BIL a call to see if he could weld it.
Ordered new gaskets consisting of three for the head and one for the turbo with some new nuts also….at the princely sum of £30 :o
So the following day I took it to his garage and he was surprised to see that it wasn’t made from cast and how flimsy it was.
Anyway he said that he would have a go at it for me but that it wasn’t in the best condition as one of the ports that connects to the head was completely loose so couldn’t promise anything. So with nothing really to loose he patched it up for me.
with a few extra welds at weak points as well…
Chuffed to bits at not spending out £350 on a new one and a promise to my BIL that I would return the favour when needed, I set off home manifold in hand :D
Re fitted it and then replaced ALL the parts that were needed to start the engine back up (left off all the trims and microfilter etc)
Waffling again more pics …
Manifold re fitted with a few parts cleaned up a little as well after all the soot/exhaust fumes …
Injectors back in…
And then fuel lines being replaced….
Etc etc until everything was back enough to start the beast back up…..hopefully :D
I would also at this point like to show you my latest in high technology tools which has on several occasions now got me out of the sh@t with dropping ratchets etc into the engine bay.
This was hand made BTW :rofl:
I then after double checking everything fired it back up. After a few turnovers to get the fuel running through again the x came back to life and a huge sigh of relief was let out accompanied by a really big grin on my boat race :yeah: :yeah:
Followed by a look of horror when after a few minutes running I pressed the loud pedal and saw a puff of smoke coming from the manifold area :headbang: :headbang: :headbang: :headbang:
Needles to say I was gutted and before reaching for the hose pipe to put in through the window from the exhaust I retired to the house and got very very drunk (said in a fast show style)
Mrs x555 said later that the hose pipe wouldn’t have worked anyway as the manifold was leaking so much :rofl: to which I pi$$ed myself laughing and thought tomorrow’s another day.
So next day back in the workshop and strip everything back apart (a lot easier this time knowing how everything came off wink smilie) to reveal the welds had held but there was exhaust fumes escaping :idunno:
on further investigation the end port closest to the egr pipe was very slightly out of line.
No fault of my BIL I might add as it was pretty shafted before and he didn’t have the car to hand to inspect either.
Tell tale signs of leak….
End port out of line…
So now I have bit the bullet and ordered a new manifold and MORE gaskets :headbang: and will hopefully re fit everything again this week. Then I can re diagnose and check for the error warning as it still could be a faulty sensor as well as the manifold….. I hope not..
I forgot to mention that I asked my BIL to take a look after re fitting the manifold and finding the smoke. So I drove to his garage (approx 4 miles ish) and went from 122 miles on the obc down to 88 by the time I got there :o (which wasn‘t happening before BTW) I was using more fuel due to the manifold leaking but not that excesive.
He then noticed a fuel leak on the return fuel line from the injectors and said that this could have been the initial rail pressure warning.
But I’m sure that it was ok before and that I must have disturbed it taking it off to remove the injectors.
Anyway I will find out this week when I get it all back together and report back.
Thanks for reading and sorry about the humongous post but it’s been an eventfull few days and I know that the pics can help as Nige’s did with me ….several times.
Not so much a how too more of a what I did but if anyone has to remove some of these parts for any reason or a similar job and needs any pointers on how too remove stuff I am more than willing to help.
EDIT: I have now made the pics a bit larger/easier to see (hope this is ok mods) messed it up before when re sizing photo's as i lost al the pics :oops: it seems i can strip down and rebuild part of the engine but not load pics corectly :rofl: that and i shouldn't post when drinking hic hic :D
5wany
Re: My manifold dilema with pics!!!
Post by 5wany » Mon Jan 17, 2011 11:46 pm
Thanks for sharing 8-)
Musta taken ages writing up post. :happyclap:
:music:
x555
Post by x555 » Mon Jan 17, 2011 11:53 pm
[quote=""5wany""]Thanks for sharing 8-)
Musta taken ages writing up post. :happyclap:[/quote]
almost as long as working on the car with my speedy typing :rofl:
thedweeb
Post by thedweeb » Tue Jan 18, 2011 12:38 am
Great write up. Hope all goes well... Dweeb
Black with Cream Pre-Facelift 3.0d sport.
AW8
Post by AW8 » Tue Jan 18, 2011 12:51 am
I thoroughly enjoy reading your posts outlining your d.i.y. efforts informative & entertaining too.
10/10 for perserverence, being methodical & in later spoting the port that was out.
I feel annoyed for you at having to go through stripping it all down yet again & hope your efforts pay off in the end.
If I was closer I would have popped in with a couple of extra beers as they may have dumbed down the dark voices in your head.
Don't wish to patronise you but for someone who often claims "I'm no mechanic" I think you have performed near miracles to date. Big respect to you.
X MAN
Post by X MAN » Tue Jan 18, 2011 1:18 am
WOW, most of us knew from your other posts you was having car trouble but you never mentioned stripping half the engine apart.
Incredible effort mate though i`m sure very stressful at times , hopefully the next time you fire it up and everything is working as it
should you will kick back with a case of beer in celebration and think about how much money you have saved in labour rates . Good luck buddy.
05 X5 3.0d
Turks
Contact:
Post by Turks » Tue Jan 18, 2011 3:49 am
Cha Ching... you have a helpful PM :thumbsup:
Great write up there Mitch, as AW8 says.. you have done a great job considering 'you are no mechanic' :D Well done so far! Hopefully the issues should be sorted very soon and you'll be back on the road happy motoring again!
Turks.
Present:
Past:
x555
Post by x555 » Tue Jan 18, 2011 8:21 am
Thanks all for the replies and i got your pm Turks.........perfect timing my man perfect :thumbsup:
gmc15
Post by gmc15 » Tue Jan 18, 2011 8:35 am
The inlet manifold cracked on my 2001 3.0d last year. I was towing and the car started to lose power and chuck black smoke out of the back :o I managed to get the car home and eventually drove it to my Indy for repair. It would drive OK on light throttle, but smoke heavily when accelerating. The garage tried to source a second hand manifold, but could not find one so fitted a new one. Can't remember the cost but it was a few hundred quid :( Apparently it is not uncommon for these to crack, and reading your post x555 I can see why now :)
Graeme.
x6 M50d
pvr
Post by pvr » Tue Jan 18, 2011 9:53 am
Wow ... that is some dismantling.
Like AW8, would not have minded holding the torch whilst you were messing about just to see how it all fits together. Well done!
911 50th anniversary -
lezmtaylor
Post by lezmtaylor » Tue Jan 18, 2011 10:28 am
Mitch, sometimes us 8 pot owners have something to be a bit smug about, I am a mechanic/ engineer with all the tools , but still would not have
relished doing that strip down.
Wish AW8 would not go on about tools though, have just ordered the magnetic rings,' just in case', although at my age 67 will hopefully never use them.
Had a tot up of my rechargeable tools and counted 45 , must have spent a fortune and some have only had single use.
Take care mate, see you at Bristol ( Just a thought can u make a copy of the disc for yourself?? I may have the rest to make a spare diag)
Sanj
Post by Sanj » Tue Jan 18, 2011 10:35 am
I know we've talked throughout this 'ordeal' but you ARE a bloody mechanic now!
:worshipbmw:
Simples...
Let me know how you get on pal - hope Turks sorted you out after the cockup on the one you missed! ;)
Serious respect.
Rick
Post by Rick » Tue Jan 18, 2011 10:51 am
What a great job you have done,i dont think there are many who would even attempt it,hope alls well when u fit the new manifold :thumbsup:
Rick
2004 4.8is Le Mans Blue
Mods,Speaker upgrade to JL Audio C5 650 CSI Comps,Pioneer TS-WX77A subwoofer,Lazer Pro Park.
Raj
Post by Raj » Tue Jan 18, 2011 10:52 am
Superb write-up. That is very good going on both the actual work, the result and the post itself.
Turks
Contact:
Post by Turks » Tue Jan 18, 2011 1:18 pm
[quote=""Sanj""]Simples...
Serious respect.[/quote]
Eh... have I missed something :poke:
Turks.
Present:
Past:
