5 3.0d air filter state !
chelsea
Post by chelsea » Sat Oct 31, 2015 4:21 pm
I started the full service on my 5 today, I cant believe the faff with removing the air filter!! It took me 30 minutes to remove it, unbelievable!!
Anyhow, once removed I found it to be in a very bad state, I don't think I have ever seen an air filter so dirty, if anyone in the know is reading this then could you take a look at the pics and advise if it is supposed to look this black after 15k-ish miles?????Image
E53 X5 SE 2005
E70 X5 SE 5S (Shadow package)2009
Z3M 1998 special order (black and red interior)
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Re: 5 3.0d air filter state !
Post by X5Sport » Sat Oct 31, 2015 4:54 pm
Looks about normal from those I have changed.  I've changed a few now and TBH one (from our 330 E46) was a lot worse as it was completely blackened!  I don't think it had been changed in 7 years - and was still under dealer support then.
It is certainly a faff to get at, hence I suspect many being left alone.
chelsea
Post by chelsea » Sat Oct 31, 2015 5:13 pm
Ok, cheers for that  ;)
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Post by Horizon » Sat Oct 31, 2015 11:53 pm
[quote="chelsea"]
Mine was a hell of a lot worse than that at 93 K when I did mine. Funny thing was it had a comprehensive BMW service history from new.
Only goes to show the dealers don't always change them at service, even though it's only on the service schedule as once every third service 60 K.
fenj66
Post by fenj66 » Sun Nov 01, 2015 12:15 am
that doesnt look bad to me. the outer "sock" can be removed and refitted the other way around for a bit more mileage. the actual filter underneath usually looks like new,
pvr
Post by pvr » Sun Nov 01, 2015 12:27 pm
On my E53, it did make an appearance at the 60k service on the bill. I can only assume it had been changed but obviously never checked.
It was an additional item to the normal "third service" routine, which included some other items as well to change.
911 50th anniversary -
chelsea
Post by chelsea » Sun Nov 01, 2015 1:09 pm
Jeez/..........done the oil change and fuel filter change today............I am pretty sure that the fuel filter has never been changed, all the bolts etc dont look like they have ever been removed at all..........what an arse of a job it is too !
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
X5-D-Sport
Post by X5-D-Sport » Sat Nov 07, 2015 1:18 pm
I swapped my OEM filter for a K&N version.... vehicle breathes a little better & is slightly more responsive.
The K&N unit is life lasting & just needs blasting out with an air line at each service.....
chelsea
Post by chelsea » Sat Nov 07, 2015 3:29 pm
...going to swap the airfilter for k and n next service !
Just serviced my wifes mondeo today and saw my old x5 fuel filter on the bench so decided to cut it open, after doing so and the colour of the filter inside then I can only assume its never been changed, it is really dirty ! My BMW service record shows it being changed twice, no chance !
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
TimX5
Post by TimX5 » Mon Nov 09, 2015 8:23 pm
[quote="chelsea"]
Acording to the service record on my x the fuel filter had been changed but it still had the original one on as there was the oem clips on never been removed.
Post by X5Sport » Mon Nov 09, 2015 9:30 pm
Sounds about right.  Owners don't check, so it's money for old rope to an unscrupulous dealer.  I now always demand the replaced parts, and warn the garage I have marked things so I know if they don't touch it.  A simple line across bolts with a UV pen is all that's needed.  If the bolts need to be removed to get at things, and don't.......
Seems to work.....but my current BMW Dealer seems OK.  The last one was a shocker.....which may be one of the reasons why they went out of business.  It's a car rental place now.
Colin
Post by Colin » Mon Nov 09, 2015 9:40 pm
its a shame you cant trust some people to do things
05 , 30d Le Mans Blue Sport
