radio
russ25
radio
Post by russ25 » Wed Oct 21, 2015 12:54 am
is it poss to upgrade standard bmw radio to dab in a 2008 x5 e70
rickyclean
Re: radio
Post by rickyclean » Wed Oct 21, 2015 6:41 pm
[quote="russ25"]
Try these chaps http://www.bmwdab.co.uk
Re: radio
Post by X5Sport » Wed Oct 21, 2015 6:53 pm
BMW do an upgrade using the PURE add on unit HD display for about £200 if memory serves.  A dealer would also be able to tell you if your standard unit can have an OEM DAB module attached, but don't expect it to be cheap and dealers are notorious for not having a clue!  Their usual answer is that if they can't find a retrofit kit then it isn't possible - even though it might be.
Put your last 7 characters of your VIN into Realoem and see if a kit shows up - possibly in the Comms or Entertainment sub sections.
russ25
Re: radio
Post by russ25 » Wed Oct 21, 2015 11:54 pm
got these from realoem.com but no prices.
No. Description Supp. Qty From Up To Part Number Price Notes
For vehicles with
Climate comfort windscreen
S358A=No
01 Digital radio retrofit kit         1 65122336500
02 Digital radio retrofit remote 1 65122337892
03 Digital radio retrofit antenna 1 65122337891
Re: radio
Post by X5Sport » Thu Oct 22, 2015 8:07 pm
Send a PM to cotswoldbmwmini - member of the Forum and a BMW Dealer who gives us discount.
russ25
Re: radio
Post by russ25 » Sat Oct 24, 2015 6:42 pm
thanks x5sport il pm them. :)
Re: radio
Post by Horizon » Sat Oct 24, 2015 6:52 pm
[quote="russ25"]
Have you had DAB radio in a car before ? I have it in my van, didn't realise it had DAB until one of the lads borrowed it and had some AM Chanel on, when I was changing the band I noticed it had DAB.
( it also had USB iPod interface, voice activation , Bluetooth front and rear PDC, heated windscreen too, better specked than a lot of new Beemers
Re: radio
Post by X5Sport » Sat Oct 24, 2015 8:49 pm
The problem with DAB is the transmitter power is only around 10% of that used for VHF FM, frequently less, and it does tend to drop a lot if you don't gave an FM alternative the radio can switch too.
pvr
Re: radio
Post by pvr » Sat Oct 24, 2015 9:09 pm
But with the FM alternative, it is slightly delayed so the last 5 seconds is repeated again.
DAB drives me mad, reception on any channel I try drops out all over the placed - including the M25 where I would expect a decent signal.
911 50th anniversary -
Re: radio
Post by Horizon » Sun Oct 25, 2015 7:13 am
[quote="pvr"]
Ahh that explains why when listening to radio 2 the other day the news was on and he repeated the same line again, didn't realise it reverted back to FM on a delay. Explains why I thought only certain stations ( those without an FM alternative seemed to drop out more often ). Thanks for the explanation.
Unfortunately I only listen to DAB to hear the channels that are not on FM.
Re: radio
Post by X5Sport » Sun Oct 25, 2015 8:39 am
The repeat is because the main broadcasts are now on DAB and retransmitted via FM which leads to a delay between the twodue to signal processing etc.  Same thing happens if you have 2 TVs on in the house and have one TV on via Freeview and one via satellite as everything usually goes out to space first, with Freeview either being fed from that or via fibre terrestrial links.
