instrument cluster
instrument cluster
hi, removed cluster weekend because mileage and temperature was very dim found very small bulbs at back removed with holders, could not get bulbs out. Can these bulbs be replaced?
- Steamyrotter
Re: instrument cluster
I believe the lamps and holders come complete??
Failing that you may be able to butcher them, but getting replacements may be a pain???
Please note...
Please note...
The bulbs and the little holders are a single item, and will most likely be destroyed in separating the two sub parts.
E-bay has them available, as they are common to many models & vehicles.
There are also colour options available.
If you go down the LED replacement route - suggest you go either ALL LED's or ALL bulbs, as the two have different light levels & will make a poor finished look if mixed.
