Propshaft Vibration X5 4D
damian777
Post by damian777 » Tue Mar 17, 2015 5:30 pm
I know that this is a topic already discussed but i had a Recall notice inspection carried out last November for Propshaft wear on my X 5  4D,( 2011 )  which had then done approx 19,000 gentle miles, no fault found by Main Dealer.  Now three months later at 23,000 miles, firstly  i have noticed a drone on the motorway when my foot is off the accelerator  ie when slowing gently for traffic etc, so no load on the propshaft. When you then accelerate again  the drone disappears, and returns  immediately you start to slow.  Secondly whilst parked ,when selecting either "D"  or  "R" during  parking i get an occasional jolt , as if slack is being taken up by the drive shaft ?
The Main Dealer  are to re inspect the car tomorow so i e mailed them to describe the sounds and driving experiences, and they said it may be a wheel bearing or the transfer box ?  As the X5 has only done 23,000 miles i would not expect gear box issues, and i have not noticed any issues going up or down the 8 ratios in normal driving.
Having carried out the Warranty recall inspectioin in November 2014, is there any reason why they cannot do it again, as my car is listed as in the batch with regards to Prop shaft problems.
Just concerned they want to bill me rather than replace the shaft under recall warranty !
Any advice on what i should do please  anyone ??
DF
Past Bm 's    M 6 ( 1986 ) ( all time favourite in 1980s  so rare  !),  M3x  2 .  540 , 3 series  loads ... X 5  x 3 .   , 2006 X 5  M Sport,   2009 D M sport in white  , Now  2011 X 5  4 D M Sport in white !
Ivory leather piped in black, Panoramic roof, camera x3 .
Re: Propshaft Vibration X5 4D
Post by X5Sport » Tue Mar 17, 2015 5:43 pm
There have been a couple of instances on here of the 8sp box and/or transfer box failing at very early miles unfortunately.  Still very very rare, but....
If it is the backlash issue it really should be changed as part of the recall process, even if it was fine four months ago.  It might have been incorrectly checked!
I would certainly expect some sort of support given the low mileage on yours though (unless you have a non-BMW warranty in which case they may well just walk away - as they did with my E53 box failure 5 years ago).
eniacs
Post by eniacs » Wed Mar 18, 2015 5:58 am
Now you mention it, my X5 does the same thing. I was thinking I was overhearing nothing, but what you describe, the light drone on the motorway when coasting. I have exactly that. Just take it back in and say you want the same thing checked under the warranty recall. Say you are concerned they may have missed somthing as your car is exhibiting symptoms of propshaft wear. Worst case they will charge you an hours labour for checking it.
damian777
Post by damian777 » Mon Mar 23, 2015 5:10 pm
Update on Dealer Visit
Yes Main BMW dealer  reinspected the propshaft for  wear on the U Joint and for circumferential play, none found. Checked Gear Box settings, oil levels and  Diff  all checked  ok , charged me  £ 65.00 which i paid .
They said my tyres  although legal  at 3- 4 mm front  and 2- 3 mm rear it may be tyre noise associated with a worn tyre as one is a part worn  which was punchure repaired , which i know about .
The overrun noise is noticable at 70 - 80 mph when my foot  is taken off the accelerator and i still find the parking selection on  D or R  a bit jolty, so cant believe its tyre related !  Ive  had two inspections now one at 19,000 miles in Nov 14  and  one at 22,800 miles  last week .
Dealer  did offer to reset gearbox program , but BMW  GB advised not.
This is my forth  X 5  , of various engine sizes and never had this drone before , anyone else experiencing this on a 4 D  X 5 ? ... :(
D .
Tommy
Post by Tommy » Mon Mar 23, 2015 8:55 pm
Got the same, sounds like gearbox tailshaft bearing to me, trailing throttle. Not had a chance to get it up in the air yet.
