Heater fan noise
AHG21
Heater fan noise
Post by AHG21 » Thu Jan 15, 2015 7:45 pm
Help please, the heater fan makes a grinding/seizing noise when it's at top speed,,if you bring the speed down it dies off a bit take it back up to top speed the noise comes back,also it seems to be pushing very little air out of the vents ? Is this a big job to replace ? And how much is a new one ?
Thanks in advance for any help.
celica
Re: Heater fan noise
Post by celica » Thu Jan 29, 2015 7:58 pm
I've got heater fan noise but it's more of a stuck valve, pulsating noise or humming
It stops if I turn the temp down, does yours stop depending on temperature setting?
AHG21
Post by AHG21 » Sun Feb 01, 2015 10:32 pm
Hi, Celica mine has been cured now it was the actual blower fan which is sited up under the passenger side footwell a half hour job done under warrenty the old fan was partially worn on the spindle new fan spun round with no drag, now no noise, I think most of the heater elements pulse there are a few threads on the forum about it, good luck with it Celica.
celica
Post by celica » Mon Feb 02, 2015 10:47 pm
Thanks for the update
