What is the most you have had out of your tyres ?
ex540d
Hello,
I have recently bought a 2010 X5 40d M Sport with 20" wheels. It has 36,000 on the clock.
The car is running on Bridgestones. Front (new) Rear (3mm)
I am looking to change the rear ones soon but i am not sure what to change them to. I would like a decent brand which last a long time as they are expensive tyres.
How many miles have people got out of a set of tyres on their X5's ?
petert
Re: What is the most you have had out of your tyres ?
I recall getting about 64000 km from my Bridgestone duellers from new. Main reason for getting them changed was that the backs had worn much more on the inside than the outside. Fronts had a bit of life left but I felt it was better to change them all.
Mind you driving is pedestrian in Canada. All straight roads and traffic lights. Tyres last longer than brake discs...
Peter T
Peter T
ex540d
Thats a lot ! What size tyres were they ?
Dunlop SP Sportmaxx. 18k and need changing soon. I suspect your car is at the end of its second set. Mine are alternated with winters so 18k is very poor in my book. I don't hoon about and even my E53 used to get another 10k on Diamaris. Used to get a lot more from non-RFT cars - up to 30k on my SkodAudi.
Never anthropomorphise computers. They hate that.- 535dboy
14k
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
technomad
[quote="ex540d"]
Hello,
My rears went on at 12000 , now on 25000 with about 3000 on winters. They're nearly shot, so that's 10,000 miles from conti contact SSRs. 40d, 19", mainly highland roads and motorways. Not good in my book but local roads seem notably abrasive. Definitely more wear on the insides and worse on the nearside overall.
Hello,
x5driver silver surfer
Hi ex540d
I have just purchased a 2011 X5 4.0D M Sport with 20"
rims and just 29K on the clock. Tyres are Dunlop RFT's
and have 6-7mm so are fairly new, therefore probably 1st replacement set. Will possibly fit non RFT's when the time comes as I am not a fan of RFT's
For supply of tyres give blackcircles.com a go. Have always found them competitive.
ex540d
Thanks for the replys
javaboss
I just replaced all my 20" Bridgestone RFTs at 21k miles.
ex540d
What pressures were you running Java ?
Graeme
I have a 2008 3.0d 7 seater with 255x50x19 x107 on the front and 285x45x19x111 on the rear, the car came with Contis that covered 25000. Next set were Bridgestones - they did 33000. Third set were Contis (much better price that for Bridgestones), however, the rears ran the inside edges to the canvas in 23000, that included a lot of towing in western Scotland and on Lewis and Harris, caused I think by a combination of pitching with the caravan weight on the back and very abrasive road surfaces. The fronts still have 5mm on them and are in store in case of need. I replaced them all with a set of new wheels that came with Contis. At present they've done 15000 - the fronts have 5mm on them, the rears are down to 4mm in the centre. All towing now done with increased pressures recommended as though the car had 7 passengers and luggage (2.7bar) , and the sport driving setting on adaptive drive! Otherwise I run the car with 2.1 bar in the fronts and 2.3 bar in the rears. The other wheels now have Vredestein snow tyres (non r'flat) and have done 6000 last winter with no obvious uneven wear. Time to put them back on! I've heard an authoritative rumour that original fitment tyres are better quality than those sold through tyre dealers as the manufacturers want a deal with the carmakers. It's one of those things - could it be true? The first set of tyres often seem to last longer!!!
Hope this helps,
Graeme
Hope this helps,
Graeme
RenoHuskerDu
I'm about to review the Uniroyal summer tyres I bought a few months back. Watch for a new post in a day or so. They are very popular here on the continent and quite reasonably priced... (teaser)
There are a lot of threads out on the web about E70s consuming tyres quickly. It's a big heavy car with a lot of torque and good brakes. As the car adverts all say in the US, "YMMV" !
Reno: Alsace, France = only 30 minutes to Germany der Vaterland!
2011 E70 40d well kitted from the factory, RaceChip 375hp
2005 E53 3.0d, manual gearbox, sport susp, RaceChip 278hp
ex540d
Thanks Graeme, Good read
I will look forward to the review Reno.
Regarding OE fitment mileages, it is well known that OE tyres usually do better than replacements due to the fact that all suspension components are new and therefore there is less movement and everything is tight and held within parameters. This also applies to trucks
damian777
Hi 540 man
Just replaced front RFT tyres on my X5 4D at 19,600 approx, they had a bald edge 18-20mm wide but 4 mm depth on the remaining 290 mm width. . The rear 315 /20 RFT have already been replaced by main dealer as i bought the X5 with 8000 miles on ,now they have 4 mm approx left across the tread, so they might just get through the winter. The front RFT 275/ 20 , i find wear on the outside edges a lot faster than my previous three X5 3 .0 D M Sports.
Two reasons i have been told cause the extra wear , and i have had tracking checked, 1) its a 4 D with 306 bhp so more torque /wear due power and 2) this car has the M sport suspension "Delete option" , so it rolls a bit more in corners . i love the M Sport looks re the body styling but not the extra firm ride so i chose this X5 three years ago . M sport suspension on BMWs is Class beating fantastic re handling ,ok on car like an M3 i owned years ago, but a bit harsh on X5s with RFTs. Both my 3 previous X 5s were 20 " RFT supplied and i never enjoyed the rumble and tram lining issues of the RFTs not to mention the tyre life or issues of a cracked rim after hitting a small pothole in my last 3 .0 M sport X 5 D, that cost me £600+ for a new rim and tyre.
With regards to comments by other people posting re OEM tyres, i suspect people who buy new vehicles drive them with kid gloves until the novelty wears off so the first set of tyres last a bit longer, and as posted the suspension settings and set up is all new so no kerb bending tracking issues. I budget for 12,000 miles on RFTs as i dont like to drive them down to legal minimums 2mm . All RFT s seem to wear adversely on one edge in one way on another, which is music to the tyre industry who are rubbing their hands with BMW owners the last ten years !
Never had 19 " on any of my X 5, but i hear they last a lot longer, and they dont throw up stones on the rear arches as much.
The other issue on RFT is that the tyre rubber is almost flush to the rim edge, so the rims on 35 profile tyres are kerbed very easily and the Diamond cut rims cost 3 x that of a standard alloy to refurbish .
standard 19- 20 " alloy £ 50 - 60 to re paint and skim, Diamond cut wheels cost nearer £ 150 each to re cut on a lathe and re paint properly ! The 333 20 " alloys on the 2010 + X 5s also oxidise as mentioned on previous posts here within a year and it appears its a battle with the dealer to get them replaced or refurbished. Hope that gives you some thoughts for tyre planning. If your doing a high mileage i would ditch RFTs when they need replacing and go for standard Goodyear or similar , with a get me home trye in the boot.!
PS why dont RFT s have a rim protection edge moulded on the tyre wall say 5mm proud ?
PPS The guy Peter T who posted here, who got 64,000 K out of his tyres ( 40,000 miles ) he must work for Bridgestone
) or drive at 30 mph everywhere in a strait line in Canada.
) Ive seen some X 5s tyres in the fitting bay that look like they have come off the Lunar Rover, chewed and bald on inside edges with the steel braid showing and 4 mm on the rest of the tyres . What a cash cow RFTs are to tyre dealers !
D
D
Past Bm 's M 6 ( 1986 ) ( all time favourite in 1980s so rare !), M3x 2 . 540 , 3 series loads ... X 5 x 3 . , 2006 X 5 M Sport, 2009 D M sport in white , Now 2011 X 5 4 D M Sport in white !
Ivory leather piped in black, Panoramic roof, camera x3 .
