Microfilter replacment
davyk31
Post by davyk31 » Sat Feb 04, 2012 7:02 pm
Called with dealer to arrange the oil service my Idrive is calling for, car is a 2008 3.0sd X5. They also say I need microfilter.
How often is this meant to be replaced?
Does it need replaced?
They quote £110 for the job, seems quite steep, is it possible to buy the part myself and is it an easy DIY? Would this be a lot cheaper?
If I decide not to replace it, is this likely to be a problem.
Doesn't seem to show as an option in the service menu in Idrive, will it therefore not really matter whether I replace or not.
Not being miserable and if it needs it done then fine but given I have 4 tyres to buy and also brakes front and rear needing done in 2000 miles I don't want to throw away my cash.
Kerryx5
Re: Microfilter replacment
Post by Kerryx5 » Sat Feb 04, 2012 7:22 pm
BMW X5 3.0D Sport 2003
dirtymonkey29
Post by dirtymonkey29 » Sat Feb 04, 2012 7:55 pm
Oil change is easy too
davyk31
Post by davyk31 » Sat Feb 04, 2012 8:37 pm
Will let the dealer do the oil change to keep the book stamped.
Thanks for the Ebay link, will this be the right part for my 2008 3.0sd?
Is it just a matter of popping over a cover to fit?
I assume there is no warnings on Idrive after replacing or any issues?
westside
Post by westside » Mon Feb 06, 2012 3:04 pm
your just have to reset the micro filter bit under the service menu. As mentioned oil is easy enough to do as well depneds how fussy you are about a stamp
davyk31
Post by davyk31 » Mon Feb 06, 2012 5:14 pm
Don't think I have a microfilter listed in the service menu, or am I missing it?
celica
Post by celica » Mon Sep 22, 2014 5:28 pm
[quote="davyk31"]
i don't think it's in the idrive
but it is programmed within the key
does bmw ones used are they carbon activated?
looking at the options on this
Post by X5Sport » Mon Sep 22, 2014 6:28 pm
The activated charcoal ones are the standard fit for cars with climate control rather than just air con.  All mine have been activated charcoal when I've removed & changed them.
Apparently for those with hay fever etc, the charcoal versions are better.  Not being a sufferer I can't confirm it.
celica
Post by celica » Wed Sep 24, 2014 11:25 am
thanks
anyone use non bmw supplied items?
99ron
Post by 99ron » Wed Sep 24, 2014 12:13 pm
3.0SD E70 M Sport.
Z4MR E85
celica
Post by celica » Wed Sep 24, 2014 1:38 pm
Crosland, not heard of them before
list price £97
Now sub £13 thats value for money for 2 carbon activated filters
Post by X5Sport » Wed Sep 24, 2014 3:45 pm
I've used Crosland before with no trouble.  Second choice would be MANN but the discounts are not so good.
Cheaper without the BBQ dust on them, but I still have charcoal ones in mine.
celica
Post by celica » Wed Sep 24, 2014 7:50 pm
I've heard of mixed reviews on croslands
Euro car part own parts with some miss match quality
Mann is probably better as oem spec
