Adding telestart t91
Timh
Post by Timh » Thu Dec 16, 2010 5:54 pm
Hi guys
I have bought a telestart t91 kit from germany and want to install it in my x5 2005 d sport.
The question is!!! Does the car have the wiring already done for this ie a plug in the boot? If not does anyone know where the wires are I need to connect. I have a harness from the telestart with 6 wires comming from it.
I noticed on here some else fitted on recently but I can't see on his pic where the wires went to.
Thanks for all your help
Tim
x555
Re: Adding telestart t91
Post by x555 » Thu Dec 16, 2010 7:07 pm
Tim I think there's a plug in the boot towards the bumper end iirc.
Brewer did this mod on the old forum and iirc Sanj knows where the plus/wires are for it because he used them for his reverse camera .....i think anyway.I can remember Jig giving him stick for using the source for the telestart :rofl: .....ohhh Sanj help please.........if you call him he comes eventually :D
Timh
Post by Timh » Thu Dec 16, 2010 7:32 pm
Found the plug!!! Just need to know which pin on the telestart I need to connect to.
3 wires on plug but 6 on telestart
Here's hoping someone knows!
Tim
tubs
Post by tubs » Thu Dec 16, 2010 8:44 pm
Check pm
Timh
Post by Timh » Thu Dec 16, 2010 9:15 pm
Replied
tubs
Post by tubs » Thu Dec 16, 2010 9:23 pm
Hope this helps Tim, didint relaise it was 3-6 pin connection
more info on Xoutpost as well
http://www.xoutpost.com/bmw-sav-forums/ ... ion-6.html
http://www.xoutpost.com/search.php?searchid=2501426
Nessimmersion
Post by Nessimmersion » Tue Dec 28, 2010 11:04 pm
Could anyone help with a similar problem.
I 've got a telestart T90, however it has 2 plugs as shown in photo Image and Image
I believe the connection I need to pug into is the one in this photo Image
Can anyone tell me if it is possible to:
a) Buy a connnector to go from one / both?? the T90 connections to the BMW plug.
b) If no connector is available - the code for an appropriate female BMW one & which cables of the 6 to connect to the 3 on the BM.
BMW x5 2005, 3.0D, Toyo Proxes for 14 months - no issues, no other mods yet
mccabema
Post by mccabema » Wed Dec 29, 2010 12:21 am
Hi-I have just bought a T91 remote kit and was wondering if you can share your experience with the install.
Is it as simple as plug and play into the slot beside the battery? (I've a 2006 3.0d with aux heat already coded).
Or is there more to it than that?
Have you managed to get it working successfully?
Thanks in advance.
Timh
Post by Timh » Mon Jan 03, 2011 5:07 pm
Right....I have just installed my telestart t91.
I too have aux heating coded and it works fine
Basically you need to wire it as follows
6 pins in telestart plug (very small numbers visible)
Red to Pin 1
White/Green to Pin 3
Brown to Pin 6
Thats it for the wiring....I cut the plug off in the boot by the stereo module (about central to the rear of car). The plug you need has 3 wires as above pic shows. My t91 came with the correct plug to fit the telestart but not the right one for the BMW plug. I soldered the connections and heat shrunk the joints.
Next you pull fuse 86 in the boot and put it back in. Hold the off button on the remote within 5 secs. That codes the remote to the telestart...
Put car back together
And that's about it....very easy to do....thanks to the guys on here who sent me photos and emails on how to wire up.
mccabema
Post by mccabema » Wed Jan 05, 2011 9:51 pm
Hi.
Could you clarify a couple of things for me?
Do you leave the 6 pin plug under the hood alone? As in the one thats actually connected to the webasto? You only need to possibly re-wire .. (or change the connector) the plug in the back?
My T91 has yet to arrive, so I don't know what plug will be on it, but from the pictures posted, it looks like the T91 might take the BMW socket in the back by the battery-maybe I'm wrong and it doesn't fit.
And with regard the pin wiring you give...thats for the plug going into the T91-again...you don't need to worry about re-wiring the six pin going into the webasto heating unit itself?
Here's what I bought-will I be able to just plug and play? No need for the blue connector and wiring? Or do I need to cut the BMW plug and then join it to pins as mentioned above?
Oh and one last thing...where did you install your antenna? Or did you need to?
Sorry...this is probably a post without patience as if my kit had arrived I would be able to see for myself !
Thanks in advance
Post by X5Sport » Wed Jan 05, 2011 10:07 pm
Been looking at exactly the same kit. Our E53 still needs 'Auxiliary Heating' I think it's called enabled, but I can get that done when the brakes are being done next week. If it is a simple as connecting the receiver into its slot in the boot, configuring the wiring to match the 6-pin VW type compared to the 3-pin BMW type then this looks incredibly simple (it helps that I are an eelektickle injuneer too 8-) ). Might be the next mod. Especially as te car has a nice new battery too.
Timh
Post by Timh » Wed Jan 05, 2011 10:09 pm
Thats the same kit I bought
If you look at the blue plug in your photo then you can see it's different to the BMW plug in the earlier post. The problem is that the telestart unit will not take the BMW plug. Hence you need to cut off the one in the boot and wire your new harness to the those cut off wires.
Your blue plug has 6 wires comming from it but you only need the 3 mention in my eairler post.
Nothing to be done under the hood...it all happens in the boot.
Hope this helps but I am sure you will see once you get the unit.
Tim
Timh
Post by Timh » Wed Jan 05, 2011 10:13 pm
Only problem is the remote fob has an Audi logo on it! Which is a sticker. I removed mine.
Is only a matter of joining the 3 wires in the boot as I said. Very simple.
Then code the remote to the car by pulling fuse and putting back in. Then press off button within 5 seconds!
Thats all there is to it!
Tim
Timh
Post by Timh » Wed Jan 05, 2011 10:19 pm
Oh sorry!
I put my antenna in the rear drivers side window. This is where BMW fit them I believe.
The BMW plug defo won't fit into the t91 it's a little narrow and the pin spacing is slightly different hence the need to basically replace the BMW plug with the blue one supplied with the kit.
Btw
There are not any instructions at all with the kit.
Tim
mccabema
Post by mccabema » Wed Jan 05, 2011 10:34 pm
:thumbsup: TimH....You are awesome !
Thanks for the clarity.
Nice and easy mod :)
