Page 1 of 2
RDC disable via bmw scanner
Posted: Tue Apr 23, 2013 7:53 pm
by Y13HYA
received my bmw scanner. installed fine and reads the car no problems. any guides on how to disable the RDC (tyre pressure system). i cant seem to fathom this....
Re: RDC disable via bmw scanner
Posted: Wed Apr 24, 2013 6:45 am
by Y13HYA
Anyone??
Posted: Wed Apr 24, 2013 7:05 am
by Raj
I looked briefly into this the other week for a forum member after doing some other work. I couldn't see a way to deactivate it but then his was a facelift so uses the ABS sensors and not the valve system.
Posted: Wed Apr 24, 2013 8:36 am
by Y13HYA
[quote="Raj"]
i keep seeing people mentioning it can be done but i couldn't figure a way to do it. i.e disable the BC warnings. i managed to code the drive off lock etc no problem.
Posted: Wed Apr 24, 2013 9:07 am
by Raj
Ah you just want to remove the check control from the dash?
In that case yes it can be done. Errr now to remember how to do it LOL
Posted: Wed Apr 24, 2013 9:13 am
by Y13HYA
[quote="Raj"]
Correct
Posted: Wed Apr 24, 2013 10:18 am
by Raj
Pm'ed buddy.
Posted: Wed Apr 24, 2013 10:22 am
by Y13HYA
However the RDC wasnt on that screen when i tried last night....
Posted: Wed Apr 24, 2013 10:26 am
by Y13HYA
the screen i had looked like this
Posted: Wed Apr 24, 2013 10:45 am
by Raj
Do you have a units drop down on the front page for RDC or TPC?
May need to go into that module if available. If not then I'm not sure. I know on the facelift there isn't an option for the TPC module as it doesn't run the delegate valves like pre-facelift.
Sorry cant help anymore than that.
Posted: Wed Apr 24, 2013 10:50 am
by Y13HYA
[quote="Raj"]
It has RDC unit option but i cant get options on it like i can with the LCM.
Posted: Wed Apr 24, 2013 9:24 pm
by malc1950
Sorry for some reason it's sent only
One page
Sent from my iPhone 5 using Tapatalk
Posted: Wed Apr 24, 2013 9:40 pm
by malc1950
Posted: Wed Apr 24, 2013 10:08 pm
by Horizon
Hi Malc
The trouble with the screen shots shown on the advert is that it only shows page one of the scan results, its maybe on page 2 or 3. I have seen the option on one of these missing pages but it doesn't show any results on mine, or yours. It says not found on ours, as we have facelift cars. If you scanned a pre facelift car it would find the module I guess. As our cars use the traction control instead, to read the low pressure by difference in rolling distance
Posted: Thu Apr 25, 2013 12:31 am
by malc1950
Hi Pete I see what u mean it only opens page one and it could be on two or three, I see your going down to Cosford at the weekend I'm thinking of going around midday for 2 or 3 hours,
I'm out Sat night so can't stop lateĀ ,
