Gear leaver won't move into manual mode
Posted: Tue Mar 29, 2016 1:43 pm
by E46ACS
Hi, not mine, but a friends. '08 3.0sd.
Was all working fine, now, in auto mode all ok, but the gear leaver will physically not move over to the left to select manual mode.
Near leaver? or worse?
Re: Gear leaver won't move into manual mode
Posted: Tue Mar 29, 2016 3:13 pm
by Nine468
Thats spooky, as mine has started doing this..
A sharp tap to the left and i found it releases. But i cant keep doing this , im guessing something is sticking...
I dont want to go spraying WD40 around it though as it might upset something... ::) ::)
Anybody any ideas.??
Posted: Tue Mar 29, 2016 8:46 pm
by celica
I suspect the lever is at fault
Lever itself is about £800 as a part I believe
Nine468, does yours spring back to park from sport mode when you press P?
Posted: Wed Mar 30, 2016 10:30 am
by E46ACS
Thanks. thought as much.
Posted: Wed Mar 30, 2016 7:22 pm
Sounds suspiciously like the joystick unit is on the way out, and it can only be replaced as a unit. BMW want obscene amount of money, but you may be able to find on line somewhat cheaper.
Realoem will give you the right part number to look for - if it goes that far.
Posted: Thu Mar 31, 2016 3:33 pm
by E46ACS
Posted: Mon Apr 04, 2016 10:49 am
by Nine468
[quote="celica"]
Mmmm, not tried that yet. i just put it back into D before i park up...
UPDATE... Yes it does spring back from sport when P is pressed....
