Parking heater remote start- Enabling
X5 ALN
Re: Parking heater remote start- Enabling
I don't have telestart - I just bridged the wires as I saw in what I thought was one of your posts.
I don't really understand multimeters (yet), And ain't no sparky. I had the multimeter set to 20k ohms and stuck a pin into each pin on the glow plug wire. Result 0.00. I was under the impression that was good as it meant the wire / element wasn't broken. (Continuity?) - now learnt otherwise - if someone can explain it in dumbass language for me it would be much appreciated ::)
The same test connected to the webasto side (thinking that was the glow plug side -doh!) read 16.0
Got the reset from post #164 and section 5 of the webasto repair manual (although maybe irrelevant for BMW)
There's a lot of pages here lol
- Rusty
[quote="jaynana"]
last but not the least, the remote start now. given the effort i've put in to this i thought of going for the 'real deal' - the GSM based remote kit.
i've found this, seems decent.
does anybody know any other GSM based remotes pls?
thx
J
Try this one...
http://www.xdrivers.co.uk/forum/https:/ ... 020#p54020
Looks similar and is cheaper
thx
J
Try this one...
Runabout - E92 3 Series Coupe
- jaynana
[quote="Rusty"]
[quote="jaynana"]
thx
J
Try this one...
i saw that, no way man, too dodgy :-[
[quote="jaynana"]
thx
J
Try this one...
- jaynana
[quote="Alan703"]
i see what you mean. apologies i thougt you were talking about the oem telestart T91 kit which i don't have.
ok yes bridging it is the right way to test. its the same as +12v to pin 1. that's the 'other end' of that wire u were previously asking about.
[quote="Alan703"]
set the multimeter to the lowest ohms settings. in mine its 20ohms. then test it. that way it will read out hte sub 1 ohm readings better. if it's still showing a 0.00 that means the glow plug is fused. or short circuited.
which possibly indicates why you get cold air on the exhaust and then the unit shuts down, cos the glow plug is fused and is not firing it up.
[quote="Alan703"]
i see, i guess i learn something everyday. can you send me that repair manual... out of curiosity.. i will PM u.
this is important though, because if your glow plug is faulty it will soon register an error in the cars and webos error memory and after that webo won't even try to start and blow cold air. then you need to reset the errors. i do this with the scanner and reslers devices.
cheers
j
[quote="Alan703"]
[quote="Alan703"]
cheers
j
[quote="Alan703"]
I remember reading something about newer cars missing stuff. Was that right.
The Mk2 X5 and the X6 do not have the Webasto as standard as they use a light alloy engine so don't need the coolant heating faster, or so I am lead to believe. Whether the earliest E70's have them I don't know, but certainly the later and LCI versions don't.
There are some around with the Webasto fitted, but it will have been a 'cost option' at the time of ordering. It's not offered as a retrofit kit.
jevansio
Hi Jaynana, just wondering what was the final thing that got your setup working, you were wondering about the dosing pump, did that end up being the case?
How does the webasto get fuel? I was under the impression there was a pump within the webasto, I didn't realise there was a pump under the car, how does the 12v on pin 1 trick also trigger the external pump? (sorry for all the questions but you seem to have a good grasp on how it works
IGNORE THAT, I just found your post explaining all here : http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=1
I've just bought an X5 purely on the basis of it having a webasto and the pin 1 test produces didly squat and I'm currently in the process of elliminating the obvious things (fuses/lockouts etc)
- jaynana
welcome aboard
it turned out to be the glow plug in my case.
it was a long journey though. through buying diagnostic tools and configuring sw for it, dismantling and servicing the webo, sending the pcb and glow plug to a service and repair shop, fixing it all back in.
all the best
all the best
jevansio
Many thanks
Yes I see, hopfully I can get this working without too much hassle
X5 ALN
I've got Progman but can't find where to return "Aux heating / ventilation" on the MID back to the original "Aux Ventilation" setting. Hopefully get my mate to do it at BMW next week.
I am under the impression as I do not have the parking heater function as standard - That when selecting Direct Heating on the MID (which i got programmed to be there), it sends the request / status checks to the various related components. The IHKA is not compatible, so shows a fault, and prevents the webasto from starting.
I've had a look with INPA and seen the water temperature rise from 49 degrees to 55 degrees - but the heater didn't seem to be running, nor was the car engine. At this point the overheating circle was black.
Dosing pump works when activated separately with INPA or DIS v57 but does not seem to run at all when a request is sent to the webasto to start. Verified the pump is working by both programs and by loud clicking, and there is a trace of diesel in the webasto exhaust and on the ground immediately under the exhaust exit.
There is an error - can anyone point me in the right direction with it????
I am fairly sure the glow plug is the fault. The wires for the glow plug (at the glow plug side) appear to be brown/yellow as if they have become really hot. This also leads me to think it is the glow plug. Does anyone know where I can buy one separately?
jevansio
The glow plug is not available seperately, you would have to buy a burner unit.
X5 ALN
[quote="jevansio"]
It is available seperate - somewhere in germany, as J got his pcb repaired and a new glow plug. Just Webasto wont sell it seperate - they must buy them from somewhere though.
see post 42
http://xdrivers.co.uk/forum/https://xdr ... hp?t=51.30
J's contact in Germany is closed this week though - so I await a reply.
see post 42
X5 ALN
[quote="wilkoturbo"]
Here how to activate with DIS v57
All done !!!
Did you do the step regarding the immobiliser in the 3rd picture?
All done !!!
- wilkoturbo
Last picture ??? Don't get ya , I just turned off for 10sec then bk on again
bmw x5 le mans blue
- fenj66
i managed to get my webasto working again in time for cold wether!
last winter my aux heater stopped working remotely for some reason. it still ran normally when the car was running but just started up, ran for about a minute then shut down when started by timer or remote.
after a bit of digging around i discovered that my auxiliary electric water pump which sits down under the passenger side headlight has stopped working for some reason. this meant that when the aux heater was fired up without the engine running, the webasto simply overheated and went into shutdown mode.
but when the car was being driven, the cars mechanical water pump was circulating the water and so the webasto kept running as normal.
after much looking around for a new pierburg auxiliary electric water pump, i could only find them in stock overseas and for a lot of money!
i decided to take a gamble and buy from ebay a second hand pump that looked identical from an e39. when it arrived i fitted it and hey presto! my aux heater now fires up and runs again.
to all those still having trouble getting their heaters to stay running, it is important to check that there is a jet of water at the top of the rad when the cap is removed to view (without engine running). if not then your webasto will just overheat and shut down..
X5 ALN
A jet of water - that splattered out o the cap when opened? That's what I was met with
