coding
Mpower
Re: coding
Post by Mpower » Mon Jun 03, 2013 10:58 am
Theres been many posts on other forums about the thefts by obd and the ways to secure your car,but as I've posted earlier the security gap on the E70/71 models have been addressed.
Bomber
Re: coding
Post by Bomber » Mon Jun 03, 2013 11:26 am
I was not told that by my friend who is a BMW master tech but I will go back to him to confirm
Mpower
Re: coding
Post by Mpower » Mon Jun 03, 2013 12:12 pm
Bomber,
Like you I have a mate who also is Bmw  master tech (just a posh term for a mechanic!) who has updated cars that can be reflashed with the latest software to prevent cloning via obd and also the prevention of windows dropping to access the obd port.
dennys
Re: coding
Post by dennys » Mon Jun 03, 2013 12:45 pm
Hi Mpower
ihas your tailgate got a button underneath to close it or is it a standard tailgate,eg can i code a stansard tailgate that just opens on the keyfob to actually power open and close with coding,
cheers
dennys
CURRENT CAR 40D M SPORT CARBON BLACK 20 INCH ALLOYS
Mpower
Re: coding
Post by Mpower » Mon Jun 03, 2013 1:07 pm
Dennys,
If you already have a powered tailgate you should have one button to open in the dash and one at the base of the tailgate.
If you don't have a powered tailgate its a no,but I've seen someone do a retrofit on an x5 but IMO its just isn't work the cost.
With coding you can open/close the tailgate by remote or the button on the dash.
Mpower
Bomber
Re: coding
Post by Bomber » Mon Jun 03, 2013 2:07 pm
[quote="Mpower"]
Bomber,
Ok thats good to hear then as my 335D was only the window fix :(
Bomber
Re: coding
Post by Bomber » Mon Jun 03, 2013 2:13 pm
Question for MPower
When I installed INPA there is no E70 on the screen however the files are present in the CFGDAT folder, in that folder there is a INPA.INI file for the settings, if i edit this this gives me E70 but is this the correct method?
Mpower
Re: coding
Post by Mpower » Mon Jun 03, 2013 2:23 pm
Bomber,
Yea thats the right method from memory and you can assign which button for E70 as you wish.
Bomber
Re: coding
Post by Bomber » Wed Jun 05, 2013 4:51 pm
Ok, coded the mirrors and and DVD in motion, working on the 6NR & 6NF now just having trouble with my build date in the VO/FA
just a note for anyone thinking of doing any coding, you will need to be very competent with a computer and have alot of time to read up, NCS is not the easiest to install as theres lots of files that you need to find elsewhere, then theres the daten files which if you like me and wanted the latest which took 4 days to download!!! there's is a small risk of buggering your car :)
Mpower
Re: coding
Post by Mpower » Wed Jun 05, 2013 6:41 pm
Bomber,
What year of build is your X,very interested in your retrofit of 6NR as I've omitted that option out when at the dealers.
I'm surprised only 2 features that you've coded I did all mine on the same day! ;)
Too be truthful anyone can code their cars but with a bit of common sense,the secret is if you're not 100% sure don't do it as you might corrupt the module that you're trying code.
Best read,read and read some more so you have a good understanding what you're doing is the key IMO!
Bomber
Re: coding
Post by Bomber » Wed Jun 05, 2013 9:58 pm
I only wanted those 2 features really, I'm having trouble with the vo date as its not letting me change, once I get this right and 6nr & 6nf working I will post everything, the wirings he easy part as far as I'm concerned
Mpower
Re: coding
Post by Mpower » Thu Jun 06, 2013 12:41 pm
Bomber,
Good progress mate keep us posted!
Bomber
Re: coding
Post by Bomber » Fri Jun 07, 2013 4:00 pm
Ok heres where I'm at, I have 6NF working which is nice but I having trouble with the Connected drive as I can't get the menu to appear so don't know if I need a FSC or not ATM.
I'll keep you updated
Mpower
Re: coding
Post by Mpower » Sat Jun 08, 2013 12:25 am
You definately require the Fsc code for connected drive then Bomber, but gotta congratulate you on the 6NF retrofit mate well done!!
Re: coding
Post by X5Sport » Sun Jun 09, 2013 9:40 pm
Defo watching this with interest having finally got 'XP Mode' running on a Win7/64 machine and learning how to install everything into a VM.  Now with the excellent advice from some folks on here it's just a case of installing everything in the right order, buy a cable and away we go........ :).........after reading War & Peace in the manuals :'(
FYI - for those going towards Windows 8, there is no XP virtual mode available, either with the top versions or to buy.  MS have discontinued it on Win8 and all XP support vanishes next spring.  Methinks BMW will have a new OS based version in development.  There's certainly a tie up between MS and BMW for upcoming models.
