Battery kill switch
sleepyfolk
Re: Battery kill switch
Post by sleepyfolk » Fri Mar 16, 2018 5:23 pm
Good kit here generally and helpful if you need advice https://www.12voltplanet.co.uk/battery-cable.html
You can get the correct terminal ends etc from them
Mercedes CLK 320
Audi A6 Quattro 2.4
briankerrys47
Post by briankerrys47 » Fri Mar 16, 2018 8:05 pm
'Just need some earth cable' Sanj :))/Raj have left country :-) :))
jeegnesh
Post by jeegnesh » Sat Mar 17, 2018 8:19 am
[quote="briankerrys47"]
There so many earth cables to choose.
Mods: H Steering, Towbar, Wide Arches, Inforad K2, HIDS, Heated Seats, PS2 Media Center, x555 Sub Box (Focal), Rear Fake Tins, RV Cam, Screen Protect, Front Tints, 168 20's, Re-Map, Black Roundels, De-badge, BSW Dash Mids, Tweeter & Xover, Rear Screens, Intravee
jeegnesh
[quote="sleepyfolk"]
Great I was getting confused with all the earth cables available.
lezmtaylor
Post by lezmtaylor » Sat Mar 17, 2018 12:11 pm
I just butchered a good quality , spare, jump lead.
Lez
jeegnesh
Post by jeegnesh » Sat Mar 17, 2018 1:59 pm
[quote="lezmtaylor"]
Lez
Creativity has no bounds.
jeegnesh
Post by jeegnesh » Sat Mar 17, 2018 2:04 pm
Does it matter if I use a longer cables so adding a max of 1.5m?
lezmtaylor
Post by lezmtaylor » Sat Mar 17, 2018 6:12 pm
I don't think so, you are not likely to get a " voltage drop", mine are about 3 feet long .
Lez
Post by Horizon » Sat Mar 17, 2018 7:54 pm
Lez
You will always get a voltage drop over a length of cable, best to run the 230 v to the charger as near as possible to the charger, as a 5 volt drop is the max allowed, a 5 volt drop at 14 volts is not an option.
Is the car parked on your property/ drive ?
If so run a length of wired armoured 3 core 2.5 mm2 cable to an external waterproof plug adjacent to your car.
If not possible, you could have problems
pvr
Post by pvr » Sun Mar 18, 2018 9:13 am
[quote="Horizon"]
Lez
I think he was talking about the negative lead interruption switch cable...
lezmtaylor
Post by lezmtaylor » Sun Mar 18, 2018 10:13 am
Well I was talking about -ve cable to kill switch.
Lez
jeegnesh
Post by jeegnesh » Sun Mar 18, 2018 1:51 pm
Correct going with negative kill switch option. Wasn't sure it would work as most solutions talk about kill on the positive but Lez has shown me it can work and a far easier option to install.
jeegnesh
Post by jeegnesh » Sun Mar 18, 2018 5:15 pm
About to order some cables, its asking whether I want m8 or m10, I am replacing the current cable so want to use the same point in the car, do I need m8 or m10 size?
Cables:
1 battery clamp to ring terminal
1 ring terminal to ring terminal
Cable Specification:
VDE 0298-4, BS638 PART 4, VDE0282-6, CENELEC HD22.6
Max Wattage (12V) : 2520W
Current Rating (A) : 285A
Rated Voltage : 100VDC/750V ac
Cable Diameter : 13.6
Ring Type: M8 or M10
Length : 48" 1200mm
lezmtaylor
Post by lezmtaylor » Sun Mar 18, 2018 5:50 pm
I'll pass on cable and ring sizes as I have a hydraulic ring crimping kit and used what was appropriate (was a few years ago that I did the job), and as said previously a good quality spare -ve jump cable
The reason I used the -ve cable from battery is :all the Bentley workshop guides talk about disconnecting the Negative battery lead when doing electric work and a battery disconnect.
Lez
jeegnesh
Post by jeegnesh » Sun Mar 18, 2018 6:33 pm
Switch has 10mm so will go M10
