E53 air con compressor not switching ON
kanewesley
Re: E53 air con compressor not switching ON
Post by kanewesley » Wed Aug 01, 2018 9:28 am
Update.......2 x compressors, 2 fans, 3 x re gasses,.....still no aircon  >:(
Can't understand why no one can mend it  :(
Post by X5Sport » Wed Aug 01, 2018 11:56 am
Control unit fault?  Can’t be much else left except sensors or wiring.
IHKA module.....
https://www.realoem.com/bmw/enUS/showpa ... Id=64_1057
They are known to fail.
kanewesley
Post by kanewesley » Wed Aug 01, 2018 12:13 pm
....And how does one prove that pray ??
Post by X5Sport » Wed Aug 01, 2018 2:53 pm
Someone else on here had an issue on their E70 and had to get a second hand one and try it.  New ones are over £500  :cry1: :cry1:
Unless an error code is being logged to give a clue, swapping it seemed (in that case) the only option.  Not ideal.
Post by henrym3 » Wed Aug 01, 2018 5:32 pm
I recently replaced my IHKA module, symptoms were no cold air, no ability to adjust fan speed, fan still running after switch off, on occasions not lighting up, I’m sure there were others. Most things pointed to FSR which I replaced but didn’t cure. Bought a second hand IHKA on line and all is good.
On the regas front I’m not convinced they vacuumed the system enough, you must have said on the second regas that you only had it done a few days ago which should have prompted them to vacuum at least 30 minutes and then stand at least 30 minutes to see if it held the vacuum.
I would be amazed if a manafacturer was allowed to fit a PRV to the system and allow it to vent to atmosphere. My understanding is that if the pressure gets to high (not being cooled by the fan coming on)it switches the compressor off. ie cuts the power to the compressor clutch. If I’m wrong then please educate me.
Post by henrym3 » Wed Aug 01, 2018 6:14 pm
I do sympathise with you, when doing my other car and questioning the a/c outlets as to what they would do I didn’t find anyone who filled me with confidence, bearing in mind that anything you/they do requires a regas to check. Then potentially it needs emptied to do anything else, very quickly becomes expensive. Most places are set up to plug in a machine which does a cycle to do a car that simply needs a regas/top up because of time.
kanewesley
Post by kanewesley » Mon Aug 06, 2018 6:52 am
We're STILL on with trying to get it going.......If and when it eventually works I'll let you knmow.
I wonder if anyone with any clout at BMW ever reads these forums???
moose04
Post by moose04 » Mon Aug 06, 2018 7:29 pm
when its had 3 x regas has then system lost its pressure each time?
Post by X5Sport » Mon Aug 06, 2018 7:43 pm
[quote="kanewesley"]
Not that we’ve ever seen a sign of......and based on others experiences with BMW GB I doubt that they would be of any use anyway. As with most other manufacturers UK centres they just don’t see any of this as their problem.
Post by henrym3 » Mon Aug 06, 2018 9:27 pm
X5Sport, I had to look up "anthropomorphise" my education ddn’t Stretch that far.
Post by henrym3 » Mon Aug 06, 2018 9:47 pm
To get back on track.http://www.autoairconparts.co.uk/VEHICL ... WLEDGE.pdf
kanewesley, you did ask for some reading on a/c.
kanewesley
Post by kanewesley » Sat Sep 08, 2018 7:30 am
>:(......3 months down the line and STILL no aircon. . . it's now throwing the aircon drive belt off so that's to sort out before we can go any further. >:(
Car now been in garage last 4 days this week and no further forward than I was 3 months ago.
I just cannot understand, why no one can mend a fridge.
Whirlpool engineers will mend and re-gas 4 - a - day !
kanewesley
Post by kanewesley » Sat Sep 08, 2018 7:42 am
Correction...now into 4th month !
Post by henrym3 » Sat Sep 08, 2018 2:08 pm
You have to get a dye added, if pressure is down every time it must be leaking, needs a dye to be able to see where.
kanewesley
Post by kanewesley » Sun Sep 09, 2018 9:20 am
It's not that its leaking henry old boy....It just won't get cold !
It's had everything thrown at it.
I dare say BMW would have a chance if they fit a new £700 compressor, a new £350 fan, new sensors and their £70 an hour labour charge.
But don't want to spend another  two  and a half grand with them on top of what I've already spent.
