Sat Nav Upgrade
jack148
Re: Sat Nav Upgrade
Post by jack148 » Fri Sep 03, 2010 10:12 am
Are their updates available for the antiquated CD system??
pvr
Re: Sat Nav Upgrade
Post by pvr » Fri Sep 03, 2010 11:05 am
Yes, you can do a direct swap to the MKIV system which is DVD based. A lot of members have done this upgrade.
Plenty of units available on ebay, usually around the £300 mark but you can get them cheaper. Also note that the Mini and Range Rover use the same unit, so don't forget to look at those as well when searching.
Sherwood
Re: Sat Nav Upgrade
Post by Sherwood » Fri Sep 03, 2010 2:27 pm
Has anyone tried the touch screen upgrade yet?
http://www.tv-in-motion.co.uk/bmw_headunit.html
BMW E53 2003 X5 3.0D
jack148
Re: Sat Nav Upgrade
Post by jack148 » Fri Sep 03, 2010 3:22 pm
[quote=""pvr""]Yes, you can do a direct swap to the MKIV system which is DVD based. A lot of members have done this upgrade.
Plenty of units available on ebay, usually around the £300 mark but you can get them cheaper. Also note that the Mini and Range Rover use the same unit, so don't forget to look at those as well when searching.[/quote]
I have looked at those units but ain't got £300 spare at the mo. Can I just get a new CD to slot in?
Jack
RichardP
Re: Sat Nav Upgrade
Post by RichardP » Sat Sep 04, 2010 1:37 pm
[quote=""pvr""]Can I just remind you all that copies of map DVDs are only legal if you have an original disk containing the same base material ... :telloff:[/quote]
I think if you follow the letter of the agreement that comes with the map disc, even making your own backup copy whilst keeping the original is ilegal.
"You may not extract or reutilise substantial parts of the contents of the Database nor reproduce, copy, modify, adapt, translate, disassemble, decompile, reverse engineer any portion of the database."
Sherwood
Re: Sat Nav Upgrade
Post by Sherwood » Sat Sep 04, 2010 6:59 pm
So is driving at 80 mph...
