EGR blanking
Re: EGR blanking
Yes that's the pipe
Is that ok to blank?
Re: EGR blanking
Used a m5 bolt and plugged it into hose
Re: EGR blanking
Since then getting a low dump valve type of noise
- Steamyrotter
Re: EGR blanking
is there any air coming out of the EGR valve where you have taken the pipe off??
Might have been better to leave pipe on and crimp it??
Re: EGR blanking
No what I mean is think air is possibly seeping through the vacuum hose when it would normally suck to open the valve
- kjb1
Re: EGR blanking
Is it worthwhile regardless to close egr valve permanently? would save inlet manifold gunking up wouldn't it. Im tempted to shut it permanently via ecu programming. What are pro's and con's?
Re: EGR blanking
No idea of whether it's a good or bad thing to do
http://www.realoem.com/bmw/showparts.do ... g=11&fg=45
No 1 here is the PRESSURE CONVERTER which I believe there is another one just the same near the turbo
I think it has an air filter on it too from reading other threads....is the noise coming from this?
Re: EGR blanking
I have no idea if I am going to be honest I am awaiting cost of new EGR from bmw
Re: EGR blanking
Guys will a EGR valve for the x5 m57 engine fit my x5 with a m57n engine?
I am getting a genuine one cheap but guy says its for m57 x5 3.0d
Re: EGR blanking
Part no 11 71 7 804 378 of one I can get hold of
